Problem with blue tooth of my IPad 2
This is a discussion on Problem with blue tooth of my IPad 2 within the iPad Help forums, part of the Apple iPad Discussions category; I am facing problem with blue tooth of my IPad2. When I switch on blue tooth the icon of blue tooth does not light. I ...
Results 1 to 10 of 12
    288770
    Apr 2013
    12
    I am facing problem with blue tooth of my IPad2. When I switch on blue tooth the icon of blue tooth does not light. I was playing music with remote JBL speaker bot now the Ipad does not discover the device thro blue tooth. Can any one help me. Whether such problem is common, what checks I should exercise to identify the problem and solve it.
    48665
    947 times
    Brisbane, Australia
    23,485
    Try a reset of your iPad and see if this helps.
    Hold the power off button and the home button simultaneously, keep holding them in and you may see the power off slide appear and disappear, wait until you see the Apple logo appear before releasing the buttons. It will take a little longer for your iPad to start.
    Please do not post twice on your issue as it divides the information given and makes it confusing for members to follow. It is also against our Forum Rules, your other post has now been deleted.
    Please read the Forum Rules
    iPad Air 128gb Wifi/Cellular - iPad 2 64gb Wifi/Cellular - iPad Mini 32gb Wifi/Cellular - iPhone 5 - Apple TV - MacBook Pro 15" - Time Capsule - Airport Express
    288770
    Apr 2013
    12
    Quote Originally Posted by leelai View Post
    I had tried earlier also but it did not work. When I switch on blue tooth the icon on pad comes but is not lighted n when I switch it off it goes. I do not know whether that is the indication of blue tooth not working. Pad is failing to discover any devices with blue tooth. Not vey conversant with forum posting I hope this quote is correct.
    I posted twice not being able to s certain whether the first one was posted in right place. sorry.
    48665
    947 times
    Brisbane, Australia
    23,485
    Quote Originally Posted by A.K.Pradhan IPad View Post
    Is the speaker you are trying to connect with fully charged. When you go into Bluetooth is this speaker already listed? Tap it and select Forget this device and then start the process again......make sure this speaker is charged first.
    Hope this helps, let us know.
    I did think you may have been having trouble with posting.....all is fine!
    288770
    Apr 2013
    12
    Is the speaker you are trying to connect with fully charged. When you go into Bluetooth is this speaker already listed? Tap it and select Forget this device and then start the process again......make sure this speaker is charged first. Hope this helps, let us know. I did think you may have been having trouble with posting.....all is fine!
    Afraid it did not work.
    48665
    947 times
    Brisbane, Australia
    23,485
    So you have other devices that your iPad can pair with? I would 'forget all of them' turn Bluetooth off and then reset your iPad. Do you have other devices that this speaker can pair with? An iPhone perhaps? Check that it isn't already paired with something else also. Does the speaker also have a setting for pairing? Turn it off in the meantime and then start the process from scratch once you have done a reset.
    That's all I've got at this point. I hope it does help!
    288770
    Apr 2013
    12
    So you have other devices that your iPad can pair with? I would 'forget all of them' turn Bluetooth off and then reset your iPad. Do you have other devices that this speaker can pair with? An iPhone perhaps? Check that it isn't already paired with something else also. Does the speaker also have a setting for pairing? Turn it off in the meantime and then start the process from scratch once you have done a reset. That's all I've got at this point. I hope it does help!
    Thank you I did as advised but did not work. My HTC mobile can discover the I Pad and I pad also discovers but can not be paired. My phone can discover and pair with JBL remote speaker thro blue tooth but I pad does not. The problem certainly appears to be with I Pad. Is there any way to instruct I Pad to forget all previous devices, as such, no device is shown on I Pad. Do give a thought. Thank you.
    48665
    947 times
    Brisbane, Australia
    23,485
    Your phone may be connecting with these speakers and this would stop the iPad being able to do so. So go into your phones Bluetooth, if the speakers are listed there, just swipe and this should bring up a Forget this device notice, then turn the bluetooth off on your phone. Once that's done, then try the iPad again.
    I'm hoping someone with more experience with this will chime in here.
    288770
    Apr 2013
    12
    Thank you. The problem was with JBL adjustment. Since then I have managed to find the problem and solve it with the help of JBL . Thank you to all. Help appreciated.
    48665
    947 times
    Brisbane, Australia
    23,485
    Thank you. The problem was with JBL adjustment. Since then I have managed to find the problem and solve it with the help of JBL . Thank you to all. Help appreciated. Sent from my iPad using iPF
    Well that's great to hear that your issue is now solved.
    And thank you for posting back and letting us know. Enjoy!!
  1. Remote for iPad blue tooth or wifi
    By Gurtaj in forum iPad Help
    Last Post: 02-28-2013, 04:53 PM
  2. Ipad and ipod connection via. Blue tooth
    By Shihid in forum iPad General Discussions
    Last Post: 10-25-2011, 11:14 AM
  3. what i can do with my ipad blue tooth ?
    Last Post: 06-22-2011, 02:28 AM
  4. Blue tooth connection between iPad and Droid
    By nateccnn in forum iPad General Discussions
    Last Post: 01-31-2011, 08:58 PM
  5. Wireless Blue Tooth Mouse and Keyboard for iPad
    By NWR in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 10-04-2010, 11:36 AM
jbl bluetooth and ipad trouble shooting
jbl bluetooth speaker not pairing with ipad 2 or air ipad
jbl bluetooth speaker to ipad 2 trouble
my blue tooth jam 2 will no longer pair with ipad air
was does my blue tooth chime and then my music shuts off
