Welcome to the new iPad Help section!
This is a discussion on Welcome to the new iPad Help section! within the iPad Help forums, part of the Apple iPad Discussions category; I am relatively new to the iPad and only found your forum a couple of days ago. What I really need now are instructions on ...
Page 21 of 27 FirstFirst ... 11 19 20 21 22 23 ... LastLast
Results 201 to 210 of 264
Like Tree12Likes
Thread: Welcome to the new iPad Help section!
  1. #201
    208448
    May 2012
    What I really need now are instructions on the forum itself.
    Sample questions;
    How do you select a portion of a item to quote?
    Some description of the use of the items at the bottom of the screen.
    If you enter a reply, must you subscribe to it or is that only a help to find it again.
    BTW in my scanning of the forum, it seems that there should be a picture somewhere to show the proper location of the iPad. The item I am referring to talked about controls in the upper right corner. In my use there are no controls there, my " home button" is on the right middle.
    Also, although this may not be the proper forum. I use shortcut keys to enter my email addresses. That includes a space at the end of them and many locations respond "invalid address" unless I go back to remove the space. Is there a way to eliminate the space?
    Thanks for any help!
  3. #202
    48665
    952 times
    Brisbane, Australia
    23,509
    Quote Originally Posted by halek
    Sample questions;
    Hi and welcome to the Forum!
    Are you using the app or the site, as you speak about the bottom of the screen I would assume the app...please correct me if I'm wrong here.
    To select a portion of a post to quote, go to the post you want to quote and you will see a blue arrow on the right, press this and you will see a quote tab press this and it will load that post. If you only want a portion of it, delete what you don't want. Make sure that the word Quote is left in at the top and bottom of this, write your post and then hit send. The quote should be in blue.
    The headings at the bottom will take you to different threads, Current is all threads that are being discussed now. Search is obvious I hope. Pressing the Forums button will take you to different Forums, press the Discussions tab and this will take you to most of the Forums we have. If you do post in a thread you will be automatically subscribed to it. You can elect to unsubscribe if you wish. If you hit the Subscribed tab this will show all the threads you have subscribed to, you can just swipe on them to bring up the delete tab if you wish.
    When speaking of the iPad and it's controls it is customary to be holding it in portrait mode. So your home button will be at the bottom in the middle.
    To edit shortcut keys, you can just go back to your shortcut in settings and take out the space you have there.
    I hope this helps you. Enjoy!
    Please read the Forum Rules
    iPad Air 128gb Wifi/Cellular - iPad 2 64gb Wifi/Cellular - iPad Mini 32gb Wifi/Cellular - iPhone 5 - Apple TV - MacBook Pro 15" - Time Capsule - Airport Express
  4. #203
    208448
    May 2012
    Thanks for your rapid response!
    I was as you surmised I was using the app. But has some further complications.
    Right now I clicked on your response and then on reply. The current screen is labeled New Reply at the top but no items at the bottom. Before I hit the reply, when I hit the blue arrow at the top it highlighted the portion of your reply where you quoted my question. I did not see how I could move or alter the selected part.
    As concerns my shortcuts, I had attempted several times editing the shortcuts, but the space is not in the characters that I entered. Apparently the space is added by the pad similar to the way it does if it offers a correction or word completion.
    I should probably note that I am a long time PC user and am not completely up on some of the iPad idiosyncrasies, like always deleting as a backspace and some of the finer points. At times I love the sensitivity of the screen but it often does things that I did not intend.
    I originally got to your app when I was trying to search using Google and got too the site which had me completely buffaloed but I noted the app and thought that it was what I needed to move around in a forum.
  5. #204
    37823
    748 times
    Cranbrook, Kent, UK
    17,132
    I'm not sure if this answers your question but check out this little pictorial guide (note, touch the images to expand them to view).......
    48665
    952 times
    Brisbane, Australia
    23,509
    Wonderful Skitch yet again Gab!
  7. #206
    37823
    748 times
    Cranbrook, Kent, UK
    17,132
    Quote Originally Posted by leelai
    Thank you.....just trying to help out here and a picture says a thousand word......or some such thing!
    97693
    858 times
    Sep 2011
    Michigan. USA
    18,178
    Hey, sweet Skitch pics, Gabe!
  9. #208
    37823
    748 times
    Cranbrook, Kent, UK
    17,132
    Quote Originally Posted by skimonkey
    Thank you too!
    208448
    May 2012
    Quote Originally Posted by Gabriel1
    Again thanks for your response and the pics.
    It seems that you may have constructed them just for to your response to me. Hopefully this reply will demonstrate that they were effective.
    Those type of details are what I was hoping to find somewhere as instructions for the app. I would sure think that you should collect those somehow to use when the next newby comes along. A comment however,certainly not as criticism but to be helpful. When I was viewing the pics the fact that I was now on the reply page was obscured by the screen # at the top.
    Is your app constructed to help people who are less skilled to do some of the things like quoting that they might not be able to do on the site? It looks like the same info is available both places.
  11. #210
    48665
    952 times
    Brisbane, Australia
    23,509
    Gab's Skitches are wonderful aren't they?
    The screen being obscured as you say, if I am understanding you correctly, is just how the iPad operates when viewing and you will notice it in many apps, the screen heading disappears and you just tap the top of the screen for it to reappear.
    The app does have the same info as the site, they are one and the same, although the app is a much simpler platform to navigate. But there are certain tasks that can only be done on the site, such as your profile and user settings.
how to unstick email on ipad
i pad 1458
ipad 1458
ipad model 1458
ipad model a 1458
ipad modela1458
model 1458 i pad
model 1458 ipad
