Wi-Fi problems
This is a discussion on Wi-Fi problems within the iPad Help forums, part of the Apple iPad Discussions category; Hi, new to the forum. Hope you can help.
I just got an iPad (Wi-Fi only) two days ago and since then I've had constant ...
Wi-Fi problems
I just got an iPad (Wi-Fi only) two days ago and since then I've had constant Wi-Fi problems when it comes out of Stand-by.
I either have to turn it off completely or "Renew Lease" in order to fix it. But that gets annoying.
Should I exchange it for another unit or is there a fix for this?
I'm using a Netgear Router and it works perfectly on my laptops and anyone's laptop that come in here.
10-01-2010 12:29 PM
Likewise, I have to constantly reset network settings, click "forget this network", re-boot, turn on Airplane Mode, etc. One continuous loop and most of the time it won't connect.
It occurs either coming out of standby or just when I power up. Have only connected twice in the past week on my network.
Everything else connects to my network (including Droid, Laptops, desktops, etc) but the IPAD. I use WPA/PSK network settings.
My IPAD software is the latest 3.2.2.
I can connect to open hotspots for the most part but sometimes experience the same problem.
Banned
It is possible, if you are having the same issues on the same wifi network, try flashing the BIOS on the wifi router. Especially if it is an older Linksys. Also, you could assign a static dhcp ip address - look at your router's help files.
If you are having this same issue on multiple wifi routers, I don't know. Personally, I have not had any issues with the wifi. I am on an un-jailbroken 3.2.2 iPad and connecting to a newer Linksys router.
I have a new Netgear modem and all my computers are doing very well on it. I have the same problems when going to a friend's house.
I returned my first iPad and am now going to return my second one, it's even worse than my first one.
Even when I connect I constantly get knocked offline so often it's annoying and there is nothing I can do other than reboot the device. After that I connect again but just a few minutes into it I'm knocked offline again I have to reboot.
The signal is reading full and very strong signal.
I've been searching the internet about this and it seems to be pretty common amongst other iPad owners.
Just enter "ipad wifi problems" in Google.
I think I'll wait for Gen 2 to come out. May give the iPad thing another go then.
Thanks for your help
Banned
It would be interesting to find out what routers everyone is using. I have not personally had any issue with the wifi with sleep mode and ip refresh. I use multiple wifi locations on a daily basis. The only ones I have issues with are locations where my laptop also has issues, so I cannot blame the iPad.
Have you tried setting a static address for the iPad on the router?
My ipad just generally seems to work slowly, compared to the computer, in respect of connecting to internet. Web sites load slowly and fail (I hate safari, but maybe it's not safari's fault?) because "server did not respond" after partial loading. Youtube clips don't show, or fail, etc. Any ideas to help?
Arcaanon your problem sounds weird.
Would love to learn more.
Anyway I returned my second iPod today.
Will wait until OS 4 is out and see what happens then or I may just wait for second generation. I doubt it's much more than four months at this point.
I love the device and miss my Chess app. Being able to lay in bed at night and play chess was a great thing!
iPad Junkie!
No problems on my side. I'm using hotspots in cafes and have the mobile hotspot from huawei e5. I was having problems sometimes when sharing my neighbors internet connection (which is the reason I switched to the mobile hotspot), but I think that was due to range problems. I sometimes noticed on that somewhat weak connection, that it makes a difference how you hold your iPad, but I guess that's already common knowledge.
Wifi issues. Way for apple to sell extended warranty?
I started experiencing the same issues as what many of you have described and when I called apple the rep informed me that my phone support had just ran out a mere 2 days before and that if I was to receive any assistance over the phone that I would have to purchase extended warranty or search the web for my own fix. I think that the antenna for the wifi is defective. Up until now I thought the iPad was the greatest thing since sliced bread now I am ready to throw it out the window. I have to practically set it on top of my router to get it to respond. The company I work for is looking to do a mass purchase but I will have to advise them of my experience, pathetic support, and have them hold off until I have found a resolution. How is it that this is not all over in the media?
" I think that the antenna for the wifi is defective. "
First the iPhone has major antenna problems now the iPad too.
- You may not post replies
- You may not edit your posts
Forum Rules
By NWR in forum iPad Help
Last Post: 08-19-2010, 11:49 AM
By zachdrago in forum iPad Hacking
Last Post: 07-01-2010, 05:38 PM
By Bungawunga in forum iPad Hacking
Last Post: 06-23-2010, 06:14 PM
By travroy in forum iPad Help
Last Post: 05-18-2010, 01:19 PM
By markerrett in forum iPad Apps
Last Post: 05-05-2010, 05:20 AM
can ipad connect to wpa-psk
how to refresh wifi on ipad
i pad gets knocked offline
ipad 2 wifi wpa-psk
ipad problem with wpa
ipad refresh wifi
ipad wifi wpa-psk
ipad wpa psk
ipad wpa-psk problem
refreshing ipad wifi
wpa-psk ipad 2
wpa-psk on ipad
