Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 21
    11374
    Aug 2010
    XXX
    8
    Unhappy HELP: iPad keeps turning off
    Hi everyone,
    I'm running a jailbroken 3.2.1 and have Backgrounder with SBSettings installed.
    iPad is running fine until an hour ago when I am reading magazine with Goodreader. Battery is 57%. Suddenly the device went dead, I turned it on again, the screen displayed big red no battery sign, and went dead again.
    I plugged in the charger then turned it on again, battery showed 56%, I unplugged, and it went dead again.
    I plugged in the charger again and performed hard reset, turned it on, it did show 57%. I browsed the web for a few minutes and then it went dead again.
    Now I am charging it with worry...
    Anybody know what could've caused this? And what should I do to fix this?
    Thanks everyone.
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    Quote Originally Posted by oe_tuning View Post
    iPad is running fine until an hour ago when I am reading magazine with Goodreader. Battery is 57%. Suddenly the device went dead...
    I think I might know what caused this.
    Restore back to iOS 3.2.2
    iPad Guru
    1284
    6 times
    Mar 2010
    2,623
    Quote Originally Posted by 1991-C4 View Post
    I had backgrounder and SBSettings on my iPad and it worked perfectly fine...that is not the reason.
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    I wasn't implying that those things alone were causing the battery issue, but we have no idea what other apps the OP downloaded... that was what I was trying to get at. Sorry for the confusion!
    iPad Guru
    1284
    6 times
    Mar 2010
    2,623
    Yes, im sure there is something installed that is causing issues. Best idea is to go into cydia and go look at what apps you have installed recently. If you have any that are system apps start deleting them...once the problem stops you found the problem. Next time read reviews before installing from cydia or rock. (rock has a better user review system, but is way less stable).
    11374
    Aug 2010
    XXX
    8
    Hi all, thanks for the responses.
    The only system apps that I installed was Backgrounder and SBSettings, and I haven't been installing any apps since last month.
    So this problem came suddenly yesterday. But I can delete Backgrounder and SB to test it out...
    Now in addition to that, something is not right with the way my ipad is charging. I charged for 7 hours and battery only increased from 57pct to 76pct. While the device was plugged in, it made beeping sound (like when you first plug in the cable) very frequently.
    Could anyone suggest what's the problem? Software / hardware issues?
    iPad Guru
    1284
    6 times
    Mar 2010
    2,623
    Firstly are you using the iPad charger? Not iPhone, they are different. If you are using the right charger it sounds like a short, either in the cable or outlet.
    11374
    Aug 2010
    XXX
    8
    Yes, Iam using ipad charger.
    Now its official that my ipad would turn itself off after a few minutes. So instead of going into standby even if I don't do any activity, it just tunr itself off.
    Help
    iPad Guru
    1284
    6 times
    Mar 2010
    2,623
    Help
    Have you tried a different outlet or cable? If it keeps making the connection sound then its either pulsing the power which is very bad for it...or its not making a clean connection.
    11374
    Aug 2010
    XXX
    8
    Quote Originally Posted by gentlefury View Post
    Help
    hi gentlefury,
    i tried a different outlet and the beeping sound stopped.
    but here are the problems now:
    1. i charged for 2 hours and the battery stays at 76pct during this time.
    2. i unplugged the charger, battery shows 76pct. several minutes later battery meter jumped to 96pct and then reached 100pct. strange...
    3. i use the device. it's still turning off by itself every few minutes, and i have to restart again.
    i already removed sbsettings, just to be safe.
  1. Turning off forum email notification
    By Dr.Gee in forum iPad General Discussions
    Last Post: 09-06-2010, 09:09 PM
ipad 2 keeps shutting off
ipad 2 keeps turning off
ipad keeps shutting off
ipad keeps turning itself off
ipad keeps turning off
my ipad keeps shutting off
my ipad keeps turning itself off
my ipad keeps turning off
why does ipad keep shutting off
why does my ipad keep shutting down
why does my ipad keep shutting off
why does my ipad keep turning off
