Urgent Help Required.
This is a discussion on Urgent Help Required. within the iPad Help forums, part of the Apple iPad Discussions category; Hey Everyone, I upgraded my iPad software to 3.2.2 and the time i installed the software, it's screen has started giving me problems of turning ...
Results 1 to 2 of 2
    8655
    Jul 2010
    Lahore, Pakistan.
    Post Urgent Help Required.
    Hey Everyone,
    I upgraded my iPad software to 3.2.2 and the time i installed the software, it's screen has started giving me problems of turning grey after 2-4 minutes. It's like once i turn on iPad, its screen automatically turns grey while all apps keep running. I push on/off button at the top couple of times and it gives dislplay again and later turn grey, whereas sometimes it works perfectly fine too. Has anyone faced the problem? How can i get rid of the problem, can somebody please help me?
    I shall be very thankful for your support and kindness.
    Regards.
    6507
    Jun 2010
    Seattle
    459
    Try turning it completely off: hold down the on/off button until you see a red slider that says "Slide to power off". Slide it to turn it off. Then once it"'s off, hold down the power button until you see the Apple logo which means it's turning on.
    If that doesn't solve your problem, try a hard reset (doesn't erase anything): press and hold both the on/off and Home buttons at the same time. Keep holding (several seconds) until you see the Apple logo. Then let go of the buttons. Let it finish rebooting.
    Good luck.
    iPAddict - 16Gig WiFi with Zagg InvisibleSHIELD Front - clear Hard Candy Sleek case - Built NY sleeve - Freedom Pro folding Bluetooth keyboard - Microsoft Bluetooth 6000 keyboard - Boxwave stylus - DIY LEGO stand, 3feet stand & DIY fold-flat stand
  1. ipad pdf problem urgent plleeaasse
    By marcusgarwood in forum iPad Help
    Last Post: 07-14-2010, 04:05 PM
  2. App Store App required for keyboard to work right?
    By LAC_STS in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 05-26-2010, 10:09 AM
  3. Sig required on ipad 3g?
    By www777 in forum iPad General Discussions
    Last Post: 04-26-2010, 02:44 PM
  4. Replies: 0
    Last Post: 03-30-2010, 01:39 PM
how to get rid of gray screen on ipad
how to remove gray screen from ipad
ipad screen goes gray
ipad screen turns gray
ipad screen turns grey
netflix gray screen ipad
what does it mean when an ipad turns red
what does it mean when an ipad turns red?
what does it mean when ipad screen turns red
what to do if your ipad screen turns red
why does ipad screen turn gray
why does my ipad screen turn gray
Tags for this Thread
