iPad won't detect USB when plugged In
This is a discussion on iPad won't detect USB when plugged In within the iPad Help forums, part of the Apple iPad Discussions category; What have I done wrong ? I've got the camera connection kit, well got 2 now I've tried my external harddrive, 2 flash drives and ...
Results 1 to 7 of 7
    288233
    Apr 2013
    Birmingham
    10
    I've tried my external harddrive, 2 flash drives and my astro headset mix amp, all show light/flash
    I have sb settings and USB toggle ( I donated )
    I've reinstalled my jailbreak using evasion
    Also reinstalled ifile
    I just can't get the USB to show when connected been trying for 2 days now,
    Guess I need to wait for 6.1.3 jailbreak so I can restore the device
    13576
    1447 times
    Aug 2010
    Western NY state (USA)
    11,055
    It's not you, the jail break, the iOS or iFile. Apple changed the power requirements (output or input) for the dock (30-pin or lightening) connector a couple of years ago. This made it so that a vast majority of USB sticks will not work with the iPad and the CCK. I understand that powered external drives may work - but not an ordinary run-of-the-mill USB stick.
    So, a lot of people have switched over and have had success with using SD/SDHC cards. I can attest that a 16GB SDHC card is recognized fine by my iPad. Oh, and I have an SD card adapter that turns the connection into a USB one and that works fine also.
    Personally, I'd give up on trying to use a USB stick. Maybe try an SD card?
    288233
    Apr 2013
    Birmingham
    10
    Quote Originally Posted by Mickey330 View Post
    Are sd cards the same that go into a hacked ds and most phones ? Becuase I got 2 8gb ones
    13576
    1447 times
    Aug 2010
    11,055
    I'm unfamiliar with what type of cards that go into a DS, but I would say yes. As long as its a data card that you can store "stuff" on, it should work.
    Oh, and in case you only have the USB part of the CCK, here's the link for the USB adapter: http://www.amazon.com/Transcend-Flas...d+card+adapter
    288233
    Apr 2013
    Birmingham
    10
    Oh, and in case you only have the USB part of the CCK, here's the link for the USB adapter: Amazon.com: Transcend P5 9-in-1 USB 2.0 Flash Memory Card Reader TS-RDP5K (Black): Electronics
    Ill take pic and send in on pc
    I got the cck with the card reader
    I also had the harddrive work twice and I got the flash drives to say no power But I can't even get them to do that now
    I take it I need to format the memory sticks to fat32
    288233
    Apr 2013
    Birmingham
    10
    deleted
    288233
    Apr 2013
    Birmingham
    10
    http://gyazo.com/ce357f4abb295252748d8eac5f8e97d6
    i
    tried the 4gb one using the adapter, and it still doesnt work i also have the cck selected on card its already fat32
  1. iPad does no sound when plugged in
    By Chase1devin2 in forum iPad 1 Forum
    Last Post: 03-08-2013, 07:22 AM
  2. New ipad battery depletion while plugged in
    By Ufo00 in forum iPad 3 Forum
    Last Post: 06-03-2012, 11:06 AM
  3. Are there problems with keeping iPad plugged in?
    By AlexisW in forum iPad 3 Forum
    Last Post: 03-24-2012, 05:31 PM
  4. Would it be bad to leave my iPad 2 on and plugged in overnight?
    By GAMESHARQ in forum iPad General Discussions
    Last Post: 01-17-2012, 08:01 AM
  5. Can I use iPad while plugged in
    By jojoe12 in forum New Member Introductions - Site Assistance
    Last Post: 12-31-2011, 07:37 AM
can ipad air recognise a usb stick
ipad detect tumbdrive
ipad won't recognise usb adapter
ipad won't recognize usb adapter
ipad wont recognize usb connector
