Wifi conection problems
This is a discussion on Wifi conection problems within the iPad Help forums, part of the Apple iPad Discussions category; Hi We have 2 ipad 3's & are using AOL BROADBAND with netgear router my problem is that I keep losing my wifi connection if ...
Results 1 to 10 of 13
    217433
    Jun 2012
    19
    Hi
    We have 2 ipad 3's & are using AOL BROADBAND with netgear router my problem is that I keep losing my wifi connection if I switch wifi on & off it works fine but connection will fail again at some point & I need to switch wifi off & on to get it back. This is the same on both iPads. My laptop desk top & ps3 work fine with no issues.
    Does any one have any ideas what may be making this happen.
    Cheers
    Shakey
    novice, learning daily....
    Moderator
    131244
    1415 times
    Dec 2011
    Regina,Canada
    18,500
    I've moved your post to the iPad help forum, where it will receive more attention.
    217433
    Jun 2012
    19
    Been told this may be a problem with the netgear router I am using, can anyone confirm this. Don't really want to buy a new router if it is not going to solves the problem
    Moderator
    131244
    1415 times
    Dec 2011
    Regina,Canada
    18,500
    Quote Originally Posted by shakeyblade View Post
    If you suspect the router, try resetting it to see if that helps, before thinking of replacing it.
    37823
    748 times
    Cranbrook, Kent, UK
    17,132
    It's also worth checking that the router firmware is fully up to date, check on AOL's website or google the model of your router (adding the words firmware update) to get details of how to do this.
    52339
    May 2011
    28
    I am having the same problem when I am streaming movies my wifi just shuts down?
    Moderator
    131244
    1415 times
    Dec 2011
    Regina,Canada
    18,500
    Quote Originally Posted by Lenc View Post
    Your WiFi connection may not have enough bandwidth to stream the movies properly.
    52339
    May 2011
    28
    It does.
    Moderator
    131244
    1415 times
    Dec 2011
    Regina,Canada
    18,500
    Are you using your WiFi connection for other things at the same time as you are attempting to watch your streaming movies?
    52339
    May 2011
    28
    No I dont
  1. IPAD Conection
    By sllauterbach in forum iPad Help
    Last Post: 06-07-2011, 11:48 AM
  2. IPAD Conection
    By sllauterbach in forum iPad General Discussions
  3. Ipad Wifi Bridge conection
    By torombolo in forum iPad Help
    Last Post: 11-21-2010, 04:54 AM
  4. Camera conection kit did you know
    By littlebuddha in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-24-2010, 11:51 AM
problem with ipad losing wifi conection
