Battery not charging correctly
This is a discussion on Battery not charging correctly within the iPad Help forums, part of the Apple iPad Discussions category; Hi
I've had my iPad about 6 weeks now and have been charging via the supplied charger and the mains, no issue at all.
However, ...
Hi
However, I came to charge it today (it was at 64%) and noticed after a few hours it was not increasing its charge. I unplugged etc and now, 7 hours later, it is still only on 68% charge?
Please can anyone help me with this issue? The small light on the charger is constantly red, stupid as it sounds I can't remember if this is "normal" as I am so used to just charging it up with no problems.
Any help very gratefully received before I take it back
Lynda
09-23-2010 01:12 PM
iPF Super Guru
Originally Posted by
lynda07
Lynda
First of all, welcome to the forum!
Now I am really bummed. I don't have any lights on the charger that came with my iPad
Are you absolutely 100% sure you are using the white cube charger that came with your iPad???
One thing you might try is to unplug the docking cable and restarting your iPad (by holding down the Home button and the Sleep/Wake button until the Apple logo comes on the screen then let it start up normally.)
And I have to ask... when your iPad is plugged into the charger, do you see a little lightning bolt in the upper right corner?
If you don't, then its not charging!
Reason: Added screen shots
No light on my iPad charger either
Al
Thanks!
Thank you so much for replying, I feel such a fool - I was using the wrong charger, I went away for the weekend and must have put the wrong charger in my iPad when I got back. As you both point out, the iPad charger has no light!!
I am now up to 87% and counting. Thank you again as I am not technical minded at all and was at a loss
Lynda
Charging while connected to PC
Hi All,
I don't seem to have a problem charging the Pad via the supplied charger, but it does not charge when connected to the PC (ie Itunes). The Ipod and Iphone charge whillst connected, is the iPad supposed to as well or am I being thick (careful how you answer that) !!
Ozzie.
The iPad takes forever when hooked up to your pc,but it does charge. As to being thick I refuse to answer that question as I am not a doctor,
Al
- You may not post replies
- You may not edit your posts
Forum Rules
By paulyeo11 in forum iPad General Discussions
Last Post: 07-30-2010, 04:55 AM
By Mexicat in forum iPad General Discussions
Last Post: 07-14-2010, 03:31 AM
By HarlyFan in forum iPad Help
Last Post: 07-12-2010, 08:51 AM
By Seadog in forum iPad Accessories for iPAD 1, 2 and 3
Last Post: 07-05-2010, 09:29 PM
By bbmountain in forum iPad General Discussions
Last Post: 06-28-2010, 03:37 PM
ipad battery indicator blinking
ipad battery light
ipad charger red light
ipad charging light
ipad charging lighter
ipad has a lighting bolt
ipad lightning not charging
ipad not charging red battery
ipad red battery lightning bolt
is a light supposed to come on when a ipad is charging?
red battery ipad lightning bolt
red bottom empty battery ipad2
