iPad will not login to library wifi
This is a discussion on iPad will not login to library wifi within the iPad Help forums, part of the Apple iPad Discussions category; Hello, Can't login to my library wifi. It is different than most other networks in that it asks for a login and password using it's ...
Results 1 to 7 of 7
    14397
    Sep 2010
    Washington, DC
    6
    Hello,
    Can't login to my library wifi. It is different than most other networks in that it asks for a login and password using it's own screen. I don't believe that it is Flash because I have connected to the network before.
    The network seems to not have any difficulty with Apple iPhones and other Apple products.
    I am an extreme newbie, I have only had my iPad for less than a month.
    For anyone with local knowledge, I am referring to a Loudoun County, VA library.
    TIA!!
    13577
    Aug 2010
    918
    I assume by "different" you mean the library is using a captive portal to control access. This is actually quite common, used in hotels, airports, and hot-spots all over the place it is used.
    If it is a captive portal, try this. Connect to the library's WiFi. Then open Safari. Open a new Safari page, not an existing page. Search for something in the search box... anything will do. It should load up the library's login page. Login, or agree to the terms, and you should be OK.
    Michael
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    My wife is a library branch manager, but unfortunately not in your system. Look for the woman wearing "sensible" shoes, with her hair in a bun and wearing her glasses on a chain around her neck and I guarantee you that is the person in charge! (I hope my wife doesn't read this!) Have you asked one of them for help? They live for this kind of thing!
    iPad Junkie!
    15345
    3 times
    Sep 2010
    New York City
    134
    The New York Public Library also uses a captive portal system where you have to click on a button on the splash screen before you get redirected to where you want to go.
    The first time I used the library network I had to go into settings to join the network so I could get my email. But after joining the network I appeared to be offline. Eventually I launched Safari and found the library's captive portal page.
    Once you know you are connected to the network try launching Safari and see if you see the library's captive portal page. If Safari shows you the last page you were on at home or another home page you may have to open a blank browser page to get to the portal (click the icon that looks like a page partially covering another page which is between the right arrow and the book icon). Then you should be fully connected and able to browse, get email or spend money in the app store.
    Hope this helps.
    A seed hidden in the heart of an apple is an orchard invisible.
    Welsh proverb
    Typo assist by iPad
    26581
    Dec 2010
    If you are referring to the issue where you are not able to connect to wifi from settings then I was in the same situation until a minute ago. I tried clicking on the name of wifi and it would error out but then I "double clicked" (two simultaneous touch) and it connected.
    Not sure if that's the fix but wanted to share
    44692
    usa
    Hi. I was just wondering if you have also tried this with firmware 4.2.1?
    Quote Originally Posted by kc2ped View Post
    Hope this helps.
    44692
    usa
    Hi. I was just wondering if you have also tried this with firmware 4.2.1? I've been trying all day and couldn't get this to work....
    Thanks in advance!
  1. Can't login? Reset password and still not working? Check here!
    By JohnnyApple in forum New Member Introductions - Site Assistance
    Last Post: 12-15-2012, 02:08 AM
  2. iTunes Library???
    By JohnMak in forum iPad Help
    Last Post: 11-22-2010, 10:56 PM
  3. Ipad wifi login problems
    By shaggy1219 in forum iPad General Discussions
    Last Post: 07-24-2010, 07:12 PM
  4. Running Banner/Splash Page after login
    By fitzswi1 in forum iPad General Discussions
    Last Post: 07-22-2010, 11:45 AM
  5. Epicurious login?
    By Dr.Gee in forum iPad Apps
    Last Post: 05-17-2010, 06:53 PM
captive network assistant ipad
how to get login page on ipad
ipad 3 when trying to connect with wifi login page trys to redirect to apple.com
ipad public wifi problem welcome page doesn't show
ipad wifi login screen
ipad wifi login screen not appearing
ipad wont display wifi login
netinary captive portal
public wifi welcome screen not showing up on ipad 2
why will the password screen not appear on ipad
wifi ipad library
wifif login won't load on ipad
