I pad 2 wont power up
This is a discussion on I pad 2 wont power up within the iPad Help forums, part of the Apple iPad Discussions category; I have an ipod 2 that wont power up, from the research I have done I have found it recommended to power it down pressing ...
Results 1 to 10 of 15
    284252
    Mar 2013
    11
    I have an ipod 2 that wont power up, from the research I have done I have found it recommended to power it down pressing home and power button and then repowering it on. if that fails then try to plug in for 30 mins to the wall and try again.
    if that doesn't work then it is most likely a hardware failure.
    I have tried charging it and it is not working- when charging it I see the battery come on the screen but it doesn't gain any charge, I also tried to plug it into my computer to connect it to itunes and it shows that it is receiving a charge from the computer on the pad but isn't recognized in itunes. if it is a hardware failure what normally goes out that would cause this? also I am wondering could it be that battery is shot... I am just wondering what I can do for trouble shooting find a the cause.
    thanks
    48665
    935 times
    Brisbane, Australia
    23,444
    Hi and welcome to the Forum!
    I'm not sure if its a reset you're trying to do.....it is done by holding those 2 buttons in simultaneously, you may see the power off slide appear and disappear. Keep holding them in until you see the Apple logo appear....the iPad should then start on its own.
    Are you using the iPad charger which came with your iPad? If its only an iPhone charger, it will charge but albeit very slowly. The same goes for charging via a computer, you will only receive a trickle charge. Did you allow the battery to run down totally? As you will need to charge it for a while before it registers enough charge to turn on. Or has your iPad laid dormant for a length of time without charge? As this can damage the battery.
    I have an iPad 2 which I've had since they were released and have used it every day for many hours and my battery is still fine.
    Please read the Forum Rules
    iPad Air 128gb Wifi/Cellular - iPad 2 64gb Wifi/Cellular - iPad Mini 32gb Wifi/Cellular - iPhone 5 - Apple TV - MacBook Pro 15" - Time Capsule - Airport Express
    284252
    Mar 2013
    11
    I have it charging with an ipad charger however it turns on when charging with a glowing black screen but still doesn't gain or hold a charge. That is part of the reason I tried to connect it to iTunes to see if maybe it was a software issue that could be restored in iTunes. I don know if this is even possible but if it is I would try
    284252
    Mar 2013
    11
    I have left it plugged in all day and now it just shows the apple icon. When I unplug it the apple icon stays on. If it was the battery I figure it should have just went off. This really has me confused.
    48665
    935 times
    Brisbane, Australia
    23,444
    Quote Originally Posted by justlearning View Post
    Try a reset if it now.
    Hold the power off button and the home button simultaneously, keep holding them in and you may see the power off slide appear and disappear, wait until you see the Apple logo appear before releasing the buttons. It will take a little longer for your iPad to start.
    Let us know what happens.
    284252
    Mar 2013
    11
    Unhappy
    I hold the power button and home button down, I never get to see the shut down slide bar come up but the screen does power down. Then to power up I see the apple icon but it never goes any further then that.
    48665
    935 times
    Brisbane, Australia
    23,444
    I'm going to transfer your thread to our hacking section.....the knowledgeable folk there may be able to suggest something more for you.
    284252
    Mar 2013
    11
    Still can't get it
    I got it! I learned how to open the ipad in DFU mode and then was able to restore the ipad!!! it looks like it is going to be good now, I have finally gotten past it apple icon!
    48665
    935 times
    Brisbane, Australia
    23,444
    Oh that is just so good to hear.......I did think that that was what was going to be recommended, but I don't know enough about those steps to guide you, whereas the hackers do.
    Thank you for getting back to us on this.....enjoy!
    146615
    2 times
    Jan 2012
    Northern Ireland
    45
    Yeah I've had this problem a few times also. The steps above always fixed it. For me it not every happens whilst I'm using the iPad and it has to shut down due to low battery. It has not happened twice in as many years so not a big issue.
  1. Power?
    By squib in forum iPad 2 Forum
    Last Post: 02-07-2013, 05:21 PM
  2. iPad wont power up, can I get some help please?
    By sealover1 in forum iPad 2 Forum
    Last Post: 11-16-2012, 06:21 PM
  3. Apps wont install an email wont update
    By jfarnan592 in forum iPad 1 Forum
    Last Post: 09-03-2012, 05:46 PM
  4. Power from USB
    By Gtatler in forum iPad 2 Forum
    Last Post: 01-26-2012, 05:54 PM
  5. why wont my work website wont work on ipad2
    By ipadguy311 in forum iPad Help
    Last Post: 07-05-2011, 03:59 PM
i pad slide bar dont come on just show aplle
ipad battery down wont power up
ipad off for days wont power up
