Twitter mobile site workaround
This is a discussion on Twitter mobile site workaround within the iPad Help forums, part of the Apple iPad Discussions category; After months with no problem accessing the full Twitter site using the Chrome browser, I discovered today that Twitter is forcing me onto the mobile ...
Results 1 to 4 of 4
    284956
    Mar 2013
    United States
    After months with no problem accessing the full Twitter site using the Chrome browser, I discovered today that Twitter is forcing me onto the mobile version of the site. I got the same result when I tried with Safari and with Atomic, a browser that others have used in the past to specifically work around this problem. Twitter used to have a mobile/standard option in their settings, but this is gone now.
    This is a problem because the Twitter mobile site only displays "Top Tweets" in its search results. The Twitter help page says it does this to manage capacity, and if you want to see all tweets, you just need to refresh the results. But this doesn't work for me -- whether I reload the results within the mobile site interface or refresh the page in the browser, I still only get the top tweets.
    Does anyone know a workaround for this that currently works? I've found numerous threads on this topic that all reference the use of settings that Twitter has since removed, or that recommend using Atomic, which still sends me to the mobile site. All I want to be able to do is see all the results in a hashtag search.
    Thanks in advance for helping do that which Twitter doesn't want me to do.
    31439
    9 times
    128
    Try adding
    default.asp?m=0
    After the backslash
    I'm guessing, but the URL should be something like twitter.com/username/default.asp?m=0
    31439
    9 times
    128
    Just tried in Safari and Puffin. Puffin allows you to set the User Agent to desktop. That hit the desktop site.
    584 times
    Dayton, WA
    13,198
    You mentioned using Atomic Browser.
    Make sure you choose a desktop browser mode under settings Identify Browser As; found under the gear icon to the left of the URL field. Close any open tabs to twitter and go to twitter again. You may need to enter twitter.com into the URL field manually.
    I just tested this, and it worked for me.
    When I changed the browser mode after already visiting the mobile site, I was stuck in the mobile site until I cleard the tab and entered the twitter URL manually. Manual entry may not be necessary. I rarely use Atomic, so I don't have a Twitter bookmark there.
  1. YouTube Mobile site?
    By Hopper200456 in forum iPad 2 Forum
    Last Post: 09-23-2012, 06:53 PM
  2. Replies: 4
    Last Post: 07-30-2012, 10:22 AM
  3. Replies: 0
    Last Post: 01-03-2012, 08:27 PM
  4. Accepting followers on Twitter using iPad Twitter app
    By mjbaertschiger in forum iPad Apps
    Last Post: 09-14-2011, 10:45 PM
  5. full website & mobile site
    By mrdinh in forum iPad General Discussions
    Last Post: 05-03-2010, 09:46 PM
full twitter site on ipad
ipad twitter full site
twitter full site
twitter full site ipad
twitter full site ipad 2
twitter full site link
twitter full site on ipad
