unsetting sentence case
This is a discussion on unsetting sentence case within the iPad Help forums, part of the Apple iPad Discussions category; Safari capitalizes the first letter of text entered in text fields, which is inconvenient when you have to enter, say, a lower-case username to login ...
Safari capitalizes the first letter of text entered in text fields, which is inconvenient when you have to enter, say, a lower-case username to login to a web resource, eg, "admin". I don't see any means to replace that capital letter with a lower case one using the iPad touchscreen keyboard. As an awkward work-around, I can go to another application, eg, Notes, put the text in the clipboard, go back to Safari and paste it into the text box. I'd be grateful for suggestions for a better approach to this problem.
09-19-2010 11:39 AM
iPF Super Guru
Originally Posted by
sidtupper
Press either one of the up arrows to change from upper case to lower case. If they are blue (like they are in this picture), that means it is in upper case mode.
iPad Enthusiast!
By default, iOS is a "Professional" so it will capitalize everything and can't be turned off. You could just press the Shift button (the arrow) before typing. That will stop it.
iPad Addict
1991-C4
sidtupper
how do you make all your arrows so straight?
Fate is not by CHANCE but by CHOICE.
iPad Master!
You can turn it off (auto caps) in your settings app, general/keyboard. Turn off auto captials
iPF Super Guru
j0yful
Practice!
BrennB
But if you do that, it will turn it off everywhere (I think) and I actually like that feature when typing.
This feature is just completely stupid for input text fields. It could be interesting in Textarea fields only. When developping a webapp for ipad it's really a big problem, end users are not happy with this feature, especially for :
- login fields
- email fields
- references fields
Grrr !!
If you don't like that feature, just turn it off - as the previous post showed.
I found an easy way to ensure all lower case entry
It's true that Safari capitalizes the first letter of an entry. If you don't want to change your general settings, there is another way:
1. Enter your userid (or whatever you need in all lower case), with the first letter repeated. That first letter will be capitalized by Safari.
2. Using Select, delete that first (duplicate) letter. The lower case userid will remain.
- You may not post replies
- You may not edit your posts
Forum Rules
By antwon412 in forum iPad Accessories for iPAD 1, 2 and 3
Last Post: 08-16-2011, 10:48 AM
By G.a.r.y in forum Off-Topic
Last Post: 05-31-2011, 09:21 PM
By FtrV8 in forum iPad Accessories for iPAD 1, 2 and 3
Last Post: 05-03-2010, 08:36 PM
By drmrw in forum iPad Accessories for iPAD 1, 2 and 3
Last Post: 04-07-2010, 07:00 AM
how do i conver lower case to upper case in pages for ipad
how to change auto capital letter on ipad
how to change to lowercase on ipad
how to make an uper case lower on an ipad signin
how to make lowercase on ipad for first letter
ipad capitalize first letter
ipad lower case
ipad upper case for first letter
ipad upper case letters
low caps on ipad
lower case on ipad
stop ipad from capitalizing first letter
Tags for this Thread
