Camera Connection Kit transfer other files?
This is a discussion on Camera Connection Kit transfer other files? within the iPad Help forums, part of the Apple iPad Discussions category; I'm a student and I'm thinking of buying an iPad. But first I've done a lot of research of how to transfer files. I would ...
Results 1 to 10 of 11
    15153
    Sep 2010
    I'm a student and I'm thinking of buying an iPad. But first I've done a lot of research of how to transfer files. I would like to be able to transfer documents I've made on Pages, Keynote, or Numbers, to other computers/devices.
    One option I've came up with is to buy a Pogoplug and use the iPad's Pogoplug app to access my USB Flash Drive wirelessly through the Pogoplug. I've been trying to find a cheaper way than that, for the Pogoplug tuns you $100, and I've found the iPad Camera Connection Kit. I was wondering whether the SD card plug-in will allow you to transfer Pages files onto the SD card.
    Also if you have a cheap way to transfer files from the iPad to other computers, please post any ideas.
    iPad Master!
    6869
    4 times
    Jun 2010
    California
    1,278
    Dropbox=free
    iPad Junkie!
    9850
    Jul 2010
    Lehi UT
    145
    USB adapter that comes with the camera connection kit allows transfer of files etc through ifile. You have to be jail broken though.
    15153
    Sep 2010
    Quote Originally Posted by Jake18oly View Post
    I wouldn't want to jailbreak it though, it would void the warranty and give it glitches. That's what happened on my iPod.
    iPad Junkie!
    2837
    Apr 2010
    marietta, ga
    211
    I use dropbos and email. Never had a problem between the two.
    iPad Guru
    1284
    6 times
    Mar 2010
    2,623
    Quote Originally Posted by BlueBaka View Post
    Wrong, and also wrong.
    15153
    Sep 2010
    Quote Originally Posted by gentlefury View Post
    Well what do you suggest using?
    12205
    Aug 2010
    Devon, England
    96
    How many times do you need to be told?
    DROPBOX!!!!!!!!!!!!!!!
    15153
    Sep 2010
    The thing about dropbox though, is that it's over the inetrnet, or, if downloaded its a file. There's no actual physical part that you can carry around.
    Also no one has answered my question if Pages documents can be transfered through an SD card.
    iPad Enthusiast!
    9915
    Jul 2010
    93
    Hello -
    They accessory has found to be able to be used on many other things then just an SD card/USB. If you want to transfer files between each other, you could jailbreak and install iFile, and plug in a SD card or a USB drive and iFile would see your files on there.
    In iOS 4.2, printing will be available which will will give you a somewhat way of sending files if you wanted to transfer them that way.
    The only way to get a file explorer is to use Dropbox, if you wanted to have a somewhat way of transferring files.
    Cheers,
    Timothy
  1. Possible to transfer MP3 files into iPad?
    By edmcfp in forum iPad FAQ
    Last Post: 05-18-2012, 08:04 AM
  2. Replies: 3
  3. Camera Connection Kit with Panasonic LX3 Digital Camera
    By Atwell in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 07-23-2010, 08:35 AM
  4. Transfer of PDF files
    By ddrmr in forum iPad Help
    Last Post: 07-02-2010, 12:31 PM
camera kit to transfer files
can camera connection kit transfer pdf file to ipad
how to access documents on connection kit with ipad
how to transfer mobi files to ipad using sd card and camera connection kit
how to transfer mp3 files to ipad using sd cck for ipad
how transfer pdf files to ipad using camera connection
ipad camera connection kit move files
ipad camera connection kit pdf files
pdf transfer ipad camera kit
transfer audio files to ipad
transfer docs to ipad via camera adapter
upload pdf to ipad camera connection kit
