please help, iPad won't charge
This is a discussion on please help, iPad won't charge within the iPad Help forums, part of the Apple iPad Discussions category; please guys, help me out.. my iPad seems won't charge.. i charge using the original 10W USB power adapter from apple. and i plug it ...
Results 1 to 8 of 8
    14996
    Sep 2010
    Somewhere I Belong
    7
    Unhappy please help, iPad won't charge
    and i plug it into the wall (not pc).
    this is my iPad display:
    it's not charging right ?
    so, what is the iPad display looks like when it's charging ??
    really need your help guys..
    thanks in advance
    iPad Addict
    6630
    20 times
    Jun 2010
    1,189
    if it's charging, the battery icon has a lightning icon cutting through it.
    Fate is not by CHANCE but by CHOICE.
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    Try unplugging the cable from your iPad and plugging it back in. If it is not in the docking port perfectly straight, this could happen. When it is plugged in properly, you should here a "tweet" sound. You will know it when you hear it!
    1596
    164 times
    Mar 2010
    4,563
    Try plugging into computer with iTunes launched if it does not charge it is an iPad problem if it starts charging then you have a faulty power charger. It also may be a bad cable
    Col
    14996
    Sep 2010
    Somewhere I Belong
    7
    j0yful and 1991-C4, thanks so much for the help..
    appreciate it..
    i figured it out already, the docking part is not perfectly straight.
    problems solved now.
    mod, u can delete this thread..
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    Good show!
    The mods generally don't delete posts unless they contain "objectionable" content. Besides, if they leave it up, perhaps someone else can benefit from your experience!
    14996
    Sep 2010
    Somewhere I Belong
    7
    hmm, that makes sense..
    so glad to be part of this great forum
    32797
    Feb 2011
    va
    Thanks for the advice! Just figured out this is the reason my iPad wasn't charging either. Looks like my iPad cover was keeping the charger from plugging in correctly.
  1. Charge ipad while OFF?
    By erpetao in forum iPad General Discussions
    Last Post: 02-19-2012, 02:18 PM
  2. Any USB hubs that will charge iPad?
    By Traveler in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 02-02-2012, 10:20 AM
  3. How often do you charge your iPad?
    By kheldour in forum iPad General Discussions
    Last Post: 05-01-2010, 05:06 PM
  4. ipad does charge using usb
    By jim_joh in forum iPad General Discussions
    Last Post: 04-15-2010, 09:23 AM
ipad 3 wont charge past 50%
ipad charges to 45%
ipad doesnt charge above 45%
ipad doesnt charge pass 5%
ipad is not charging past 45%
ipad not charging past 5%
ipad not charging past 50
ipad will not charge above 50%
ipad won't charge past 5%
ipad won't charge past 50
ipad wont charge past 5%
why is my ipad not charging over 60%
