iPad 2 dead - advice?
This is a discussion on iPad 2 dead - advice? within the iPad Help forums, part of the Apple iPad Discussions category; Hi, I've been trying to help my Dad with his broken iPad2. He doesn't know what iOS version he had on the device prior to ...
Results 1 to 3 of 3
    277067
    Feb 2013
    Hi,
    I've been trying to help my Dad with his broken iPad2. He doesn't know what iOS version he had on the device prior to it playing up.
    I've tried restoring the iPad via iTunes - everything seems to go ok, but the problem doesn't go away. I then tried using TinyUmbrella tool to fix recovery mode, and also to try and exit recover mode, neither seems to work.
    The iPad will go into DFU mode ok, and recovery mode - using neither seems to make a difference.
    I tried restoring an older iOS version, but get the 1601 error.
    I have attached the log details from TinyUmbrella in the hope that someone can point me in the right direction.
    Beginning to get to my wits end!
    Cheers,
    Gareth
    167823
    16 times
    Feb 2012
    Brooklyn, New York
    332
    Define "dead". What's going on with the device and what are the specific errors that iTunes or your device is spitting out. What's being displayed on your iPad's screen. According to the logs, it doesn't seem like the iPad 2 with 3G capabilities has had its SHSH blobs saved, so you won't be able to downgrade. Unfortunately, unless the device is in its normal state, we can't find out what the iOS on the device is or was.
    Error 160X refers to a USB error. Unplug the iPad, uninstall the USB port drivers, reboot your computer and retry. If that doesn't work, you'll need access to another computer.
    iPhone 4S White 16GB iOS 6.1.2 || iPad 2 (Black) 16GB WiFi iOS 6.1.2 || iPhone 5 (Slate)/iPhone 4S (Black) 64GB Latest Beta/Full iOS
    iPhone Forums Moderator
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    Follow our guide here, and it should get you back and running on iOS 6.1 - http://www.ipadforums.net/ipad-hacki...rsion-ios.html
    Follow all the steps and advice in the guide carefully
  1. Help! My Ipad is dead!
    By adjeff in forum iPad Help
    Last Post: 10-28-2012, 01:21 PM
  2. Replies: 8
    Last Post: 01-25-2011, 11:43 PM
  3. IPAD Dead?
    By cosmonaut in forum iPad General Discussions
    Last Post: 01-11-2011, 03:57 PM
  4. Dead iPad
    By woodturner in forum iPad Help
    Last Post: 09-11-2010, 11:42 AM
ipad 1 dead
