Ipad won't turn on - whatever I do!
This is a discussion on Ipad won't turn on - whatever I do! within the iPad Help forums, part of the Apple iPad Discussions category; Hello Ipadforums,
yesterday I was just having fun on my ipad, doing whatever, when it seemed to just shut off. I had stopped using it ...
Hello Ipadforums,
yesterday I was just having fun on my ipad, doing whatever, when it seemed to just shut off. I had stopped using it for a while, but when I went back to it it seemed to be dead.
This was odd, considering the fact that I just had it at above 20% and only stopped using it for 10 minutes.
So, I tried to turn it back on, and it didn't turn on. I also noticed that the battery symbol wasn't flashing.
After I noticed that I plugged it into the wall for a while, still no battery symbol or sign of life whatsoever in my device.
After that I tried a hard reset. That failed too.
So, finally, I tried to plug it into iTunes.
iTunes didn't recognize my iPad - In fact, it seemed to confuse it with another iPad. A window reading 'looking for iPad' flashed for about 2-5 seconds before nothing really happened.
Is there some form of hardware failure in my device? Should I go to the apple store, and if I should, does anybody know if there's a cost?
Thanks,
TehRealTBL
01-28-2013 06:15 AM
Is it still under the 1 year warranty? You can contact apple and they will arrange a repair for you, you can post it off or take it to your nearest store. Mine also has done this once or twice recently, and I think mine is a ram issue as its getting really slow and unresponsive. However luckily mine has turned back on. I've only had my iPad 2 for 11 months now.
So is it completely dead, did you try plugging it into iTunes and using DFU mode? Do you get the USB icon saying connect to iTunes? How long did you charge it for? Sometimes it can turn itself back on after charging 5 mins. Sometimes the buttons stick, so do check that's not the issue also. What was you doing with it when it crashed? Have you ever dropped it or spilt anything on it? Hope you get it sorted but the answer is likely to be check your warranty with apple and it should be free repair if it's still under warranty.
Take the warranty it seems something is broken in the hardware
Maybe something is wrong with the battery....Check with your nearest Apple Store....
Sent from my iPad 32GB using iPF
Moderator
Maybe there's a fault in the battery wiring, with no power getting to the device? I think you should make a Genius Bar appointment at an Apple store to have it checked out. If there's a fault with the iPad, is should be covered under warranty.
- You may not post replies
- You may not edit your posts
Forum Rules
By Toeslider in forum iPad Mini Forum
Last Post: 12-15-2012, 08:56 AM
By col.bris in forum iPad General Discussions
Last Post: 11-16-2012, 12:35 AM
By Maura in forum Apple iPad News
Last Post: 10-01-2012, 12:24 PM
By jemorgan3 in forum iPad General Discussions
Last Post: 09-27-2011, 11:05 PM
By zman in forum iPad Apps
Last Post: 06-03-2010, 03:34 AM
dropped ipad won't turn on
dropped ipad wont turn on
dropped my ipad-won't turn on
ipad mini will not turn on
ipad mini won't turn on
ipad mini won't turn on.
ipad mini wont turn on
ipad won't charge -ipod -phone
ipad won't turn on
ipad won't turn on charge
my ipad mini wont turn on
my ipad shut off an wont turn on what should i do
