IPAD 3G 64GB - Locked @ "Connect to Itunes" screen
This is a discussion on IPAD 3G 64GB - Locked @ "Connect to Itunes" screen within the iPad Help forums, part of the Apple iPad Discussions category; As subject, my 3G Ipad got locked on "Connect to Itunes" screen. Whenever i plug it into itune, it said my pad is on recovery ...
Results 1 to 1 of 1
    14941
    Sep 2010
    Indonesia
    As subject,
    my 3G Ipad got locked on "Connect to Itunes" screen. Whenever i plug it into itune, it said my pad is on recovery mode, and need to restore, i downloaded 3.2.1 OS and restore it and after around 99%, i got an error, after reading the log file, it says error 1103.
    Done alot of googling, and found that it is recovery mode reboot loop error.
    1. Tried tinyumbrella to 'kickstart' the but it doesn't work.
    2. Irecovery Method doesn't seems to make it start too.
    Anyone had this problem before? is there a solution for this problem?
  1. Replies: 15
    Last Post: 06-20-2011, 02:24 PM
  2. Can an iPad be "locked down"?
    By ksaneii in forum iPad Development
    Last Post: 11-10-2010, 01:22 PM
  3. My iPad went "Blue Screen" and...
    By aaron.tan.munloong in forum iPad Help
    Last Post: 08-14-2010, 08:38 AM
  4. Safari stuck on "Apple-Legal-iTunes" screen
    By iBean in forum iPad Help
    Last Post: 06-09-2010, 06:56 PM
  5. Can an iPad be "locked down"?
    By ksaneii in forum iPad General Discussions
    Last Post: 04-19-2010, 10:27 PM
can not get the itunes plug in off of my ipad screen
i pad saying plug into i tunes
ipad 64gb is lock
ipad connect to itunes screen
ipad just says connect itunes
ipad says itunes screen
ipad says plug into itunes
ipad says plug into itunes?
ipad that say plug into itunes
ipad upgrade says plug into itunes
my ipad is broken, when i turn the screen on, it says itunes plug in
my ipad says plug into itunes
