Password Locked IPAD stuck in "Connect to itunes" mode
This is a discussion on Password Locked IPAD stuck in "Connect to itunes" mode within the iPad Help forums, part of the Apple iPad Discussions category; My jailbroken IPAD 3G 64GB suddenly decided to go to the "Connect to Itunes" screen. The first time, I rebooted it and it was ok ...
Results 1 to 10 of 16
    14764
    Sep 2010
    delhi
    14
    My jailbroken IPAD 3G 64GB suddenly decided to go to the "Connect to Itunes" screen. The first time, I rebooted it and it was ok and came back to regular mode. After a few hours, its gone back to the "Connect to Itunes" screen, and this time, I have tried to connect it to itunes on my computer (to which it regularly gets synced) but as the ipad is password locked, the computer refuses to connect to it saying that the ipad is locked, and cannot be synced.
    How do i rectify this?? Anyone else had the same problem??
    Thanks a lot!!
    14764
    Sep 2010
    delhi
    14
    Update to the situation.. after a number of hard reboots, the ipad came back to life, and the first thing I did was to remove the password lock. It worked for about half an hour before heading back to "Connect to itunes" screen. It didn't start on multiple reboots and has sprung back to life again after connecting it to the computer (itunes). I am not sure when it could go back to the same mode. Any suggestions/ideas on how to prevent it from crashing again?
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    perform a restore, if it happens after the restore, take it back for a new one.
    8050
    Jun 2010
    Churchill Falls, NL, Canada
    12
    Mine done the same thing but a restore fixed her up like new
    The New iPad 64 Gig White
    Ipad Mini 32 Gig
    16624
    Oct 2010
    hi ya how did you reboot her i have the same problem and only bought it yest thanks
    iPad Master!
    6869
    4 times
    Jun 2010
    California
    1,278
    Reboot, hold the power button down to "slide to power off" slide, then wait a few mins and turn back on...
    Reset, Hold power button and home key (circle button) down past the "slide to power off" screen until the apple logo comes up...
    You won't lose info.
    14764
    Sep 2010
    delhi
    14
    Ok, I've been struggling with mine ever since. Restore did seem to have fixed it up temporarily though.
    My ipad is a 64GB 3G. It's on 3.2.1 and jailbroken with jailbreakme.com. I have been restoring it back to 3.2.1 by holding the alt key when clicking restore, and changing the hosts file by adding
    74.208.10.249 gs.apple.com
    to fool the system into checking with apple that I am restoring it with the latest copy of the OS.
    It works fine with just a normal restore, but after jailbreaking it again, and installing ***** REMOVED ***** as well as restoring all the downloaded apps, and then switching on the 3G network, it becomes unstable. Either there is a problem with the jailbreak which makes it unstable and takes it to the initial activation screen with "Connect to itunes" when rebooted, or there is a problem with ***** and installing the other apps, or something is interfering with the network capabilities (3G) and it crashes due to it. I am unable to figure out clearly.
    I've gone through this process multiple times now, but there isn't any clear point where the problem starts. And once the problem starts, it doesn't show up every time. At times, I am able to reboot it normally, at times it boots only when connected to the computer.. and at times, it takes many times to be able to boot up..
    Any help would be greatly appreciated!
    Last edited by f4780y; 06-20-2011 at 02:26 PM. Reason: reference to pirating removed
    14764
    Sep 2010
    delhi
    14
    My problem seems to be stemming very early.. I rebooted my ipad right after restoring it with ipad 3.2.1 firmware, and rebooted it.. it went straight to the "Connect to itunes" screen. Should I try the latest firmware.. would it help? I would have to lose my ability to jailbreak in that case..? I had bought it in UK and am now in India. So its not possible to return it and get a brand new one easily.
    Supporting Vendor
    456
    Feb 2010
    Asia
    1,272
    Smile
    Quote Originally Posted by vb7ue View Post
    Hi you are one of the hundred example of how the JB is like a pain in the ass … if you want to have your device working you have to restore it and forget your JB otherwise the only solution you have but not so sure your problem will be solved at 100% …
    is install one by one each JB app’s and try , if no trouble install the next until you find witch one made the device unstable
    the problem can come from only one app’s or the combination of two
    PS: for exchange you can return it India Apple service center :
    India (91) 1800 4250 744
    or
    (91) 80-4140-9000
    Apple - Support
    Hope that help
    Nobody is perfect and me the first
    Ipad essential accessories
    14764
    Sep 2010
    delhi
    14
    I've figured out that the problem is not with the jailbreak. It is with the 3g network.
    I restored my ipad with 3.2.1 firmware and then set it up as a new ipad without restoring any apps. I then rebooted the ipad with success multiple times to confirm that there wasn't any problem. Even though I had a sim card placed in the holder, it only showed my an iPad at the top left (just like an Ipad wifi). I then reset the network settings and it rebooted and voila - I was again left at the connect to itunes screen. And after connecting it to itunes, and rebooting it multiple times, the ipad remains stuck on the "Connect to itunes" screen, and the Macbook refuses to recognize it... saying i need to restore. So the problem is not with any jailbreak but with the 3g. Any idea if this is a common issue?
  1. Hello! I came here b/c my iPad is stuck in "Edge mode"
    By birdbathbuzz in forum New Member Introductions - Site Assistance
    Last Post: 04-02-2011, 06:13 PM
  2. Can an iPad be "locked down"?
    By ksaneii in forum iPad Development
    Last Post: 11-10-2010, 01:22 PM
  3. Cydia stuck at "Downloading Sources"
    By Generalgergles in forum iPad Hacking
    Last Post: 08-08-2010, 03:28 PM
  4. Safari stuck on "Apple-Legal-iTunes" screen
    By iBean in forum iPad Help
    Last Post: 06-09-2010, 06:56 PM
  5. Can an iPad be "locked down"?
    By ksaneii in forum iPad General Discussions
    Last Post: 04-19-2010, 10:27 PM
how to restore a locked ipad
how to restore locked ipad
ipad is locked with a passcode
ipad locked
ipad locked connect to itunes
ipad locked with passcode
ipad password
ipad password locked
ipad stuck on itunes
itunes could not connect to the ipad
itunes could not connect to the ipad because it is locked with a passcode
locked ipad
Tags for this Thread
