Password Locked IPAD stuck in "Connect to itunes" mode
This is a discussion on Password Locked IPAD stuck in "Connect to itunes" mode within the iPad Help forums, part of the Apple iPad Discussions category; Originally Posted by vb7ue
I've figured out that the problem is not with the jailbreak. It is with the 3g network.
I restored my ipad ...
Supporting Vendor
vb7ue
I restored my ipad with 3.2.1 firmware and then set it up as a new ipad without restoring any apps. I then rebooted the ipad with success multiple times to confirm that there wasn't any problem. Even though I had a sim card placed in the holder, it only showed my an iPad at the top left (just like an Ipad wifi). I then reset the network settings and it rebooted and voila - I was again left at the connect to itunes screen. And after connecting it to itunes, and rebooting it multiple times, the ipad remains stuck on the "Connect to itunes" screen, and the Macbook refuses to recognize it... saying i need to restore. So the problem is not with any jailbreak but with the 3g. Any idea if this is a common issue?
Concerning the 3G , maybe you need to enter the APN setting …. you can try to use RecBoot 1.0.2 but not sure that will solve definitively your problem … it have solve many case i know but your look like more complicated
10-04-2010 10:26 PM
Same issue. I had the issue with 3.2.1 I updated it to the latest version last week...got same issue. After dozens of reboots the ipad allowed me to enter the passcode. I then restored the ipad back to factory settings, then installed my apps and content. It has now locked again this time (after about 30 reboots - still no way to get in). Called Apple...they just want to sell me a support contract. This seems to be a common issue and I can't believe this 'easy to use device' is so bl**dy temperamental. Seems from my research there is no answer out there for this issue - clearly this is a bug that is effecting many people.
If you are able to unlock it, don't put the password on. It's much tougher to get it working with the pwd enabled. I figured it was probably something in my 100 odd apps downloaded. I did a fresh install and did not recover it from backup. I've upgraded it to 4.2 and haven't jail broken it and it's behaving fine now. I do dread the "connect to iTunes" screen. But not sure whom to blame.. Apple or some random app I had.
vb7ue
My jailbroken IPAD 3G 64GB suddenly decided to go to the "Connect to Itunes" screen. The first time, I rebooted it and it was ok and came back to regular mode. After a few hours, its gone back to the "Connect to Itunes" screen, and this time, I have tried to connect it to itunes on my computer (to which it regularly gets synced) but as the ipad is password locked, the computer refuses to connect to it saying that the ipad is locked, and cannot be synced.
How do i rectify this?? Anyone else had the same problem??
Thanks a lot!!
I have the same problem as his. Tried the suggestion even if mine isn't JB. Still the computer refuses to connect and sync.
It's frustrating....
Will I get a replacement?
how i restore my ipad? it is currently stuck at the "connect to iTunes" screen. I saw several of you mention it, but not give directions on how to restore. My computer also only sees it as an iPad camera, and my iTunes doesnt see it at all, does anyone know how to fix this without me having to send it back?
OK, so your computer sees the iPad because you can see the photos in the camera roll, right?
But you start iTunes and you cannot see anything?
That is strange, but the first thing to try is to reboot the PC (not the iPad). Then reconnect the iPad and start iTunes. It should see the device in recovery mode and ask you if you want to restore it...
13" MacBook Pro 8GB 2.7GHz i7 500GB | iPad3 4G 64GB 5.1.1 (stock) | iPad2 3G 64GB 5.0.1 (absinthe) | iPad1 3G 64GB 5.1.1 (redsn0w) |
iPhone4S 64GB 5.0.1 (absinthe) | iPhone4 32GB 4.3.3 (jbme 3.0) | iPhone3G 16GB 3.1.3 (jbme 2.0) |
iPod Classic 6G 160GB (stock) | AppleTV 2G 4.4.4 (seas0npass)
If it ain't broke... Jailbreak it!
- You may not post replies
- You may not edit your posts
Forum Rules
By birdbathbuzz in forum New Member Introductions - Site Assistance
Last Post: 04-02-2011, 06:13 PM
By ksaneii in forum iPad Development
Last Post: 11-10-2010, 01:22 PM
By Generalgergles in forum iPad Hacking
Last Post: 08-08-2010, 03:28 PM
By iBean in forum iPad Help
Last Post: 06-09-2010, 06:56 PM
By ksaneii in forum iPad General Discussions
Last Post: 04-19-2010, 10:27 PM
how to restore a locked ipad
how to restore locked ipad
ipad 2 connect to itunes
ipad 2 stuck on itunes
ipad connect to itunes
ipad is locked with a passcode
ipad locked
ipad locked with passcode
ipad password
ipad password locked
ipad stuck on connect to itunes
ipad stuck on connect to itunes screen
ipad stuck on itunes
itunes cannot connect to ipad because it is locked with a passcode
itunes could not connect to ipad because it is locked with a passcode
itunes could not connect to the ipad
itunes could not connect to the ipad because it is locked with a passcode
itunes could not connect to the iphone because it is locked with a passcode
locked ipad
restore locked ipad
Tags for this Thread
