New ipad drops wifi connection
This is a discussion on New ipad drops wifi connection within the iPad Help forums, part of the Apple iPad Discussions category; When I close the cover, which then puts the iPad to sleep, it closes down the wifi connection. When I open the cover, I have ...
Results 1 to 10 of 13
    247844
    Sep 2012
    UK
    126
    When I close the cover, which then puts the iPad to sleep, it closes down the wifi connection. When I open the cover, I have to wait a few minutes till its connected again. This has only just started to happen. Does anyone know why it's started to do this and can I work around it?
    New iPad 32gb WiFi 3G
    iPad Addict
    168139
    52 times
    Feb 2012
    Brisbane, Australia
    1,149
    It is normal behavior for the iPad to drop the wifi connection when asleep. It sounds like it is taking unusually long for it to come back up, which is the real issue. It may be related to your wifi router as well. Maybe delete the wifi connection from your iPad and re-enter all the details again.
    dhewson777
    Brisbane, Australia
    iPad 2 , iPhone 4, MBA 11"
    Yes, I have windows PCs as well! (too many to list)
    89227
    5 times
    Aug 2011
    UK
    282
    if you have not secured your WiFi, likely you have many WiFi users leeching your connection. Each takes one of the available addresses of your router, the less free addresses the longer it takes to be logged on.
    247844
    Sep 2012
    UK
    126
    Thanks for both suggestions will try resetting everything.
    My wifi is very secure, I can see who is logged on at all times.
    89227
    5 times
    Aug 2011
    UK
    282
    Quote Originally Posted by lizzieh
    my wife's laptop had the same issue, so try using a fixed ip on you phone, say xxx.xxx.xxx.200, then limit the dhcp server (in the router) to 'allocating' auto addresses below this, might speed things up as it will not need to test each address to see if it us free.
    247844
    Sep 2012
    UK
    126
    Thanks, but I wouldn't know how to do that.
    247844
    Sep 2012
    UK
    126
    I'm still losing the wifi - is anyone able to help me?
    Tks
    247820
    7 times
    Sep 2012
    Australia
    157
    Are you in an area of good signal strength?
    Are there any/many walls between the iPad and the wireless modem/router?
    Have you tried other locations?
    247844
    Sep 2012
    UK
    126
    I am only a few feet away from the router. I am going to sons house later, will see what happens whilst I'm there.
    Thanks for replying.
    247820
    7 times
    Sep 2012
    Australia
    157
    Good luck.
    I have (in Settings/General) iPad cover lock/unlock = Off.
    This saves fluffing around with using covers to turn it off.
    Auto lock set to = 2 minutes.
    On reawakening I get wifi fast as.
  1. ipad camera connection kit drops connection
    By stingray1059 in forum iPad Help
    Last Post: 12-25-2011, 06:19 PM
  2. iPad 2 wifi connection drops intermittently....problem solved
    By Appsolutecreations in forum iPad General Discussions
    Last Post: 11-08-2011, 08:46 AM
  3. Ipad drops wifi connection
    By nickwebster in forum iPad Help
    Last Post: 07-29-2011, 07:55 PM
  4. Wifi Drops Connection When Idle
    By freescalpel in forum iPad General Discussions
    Last Post: 06-28-2011, 06:49 AM
  5. Wifi connection drops solution!
    By Itzxdjx in forum iPad General Discussions
    Last Post: 04-18-2010, 01:17 PM
ipad 3 drops wifi connection
ipad dropped wifi connection
ipad drops connection
ipad drops wifi
ipad drops wifi all the time 2013
ipad drops yfi
ipad sleeps drops wifi connection
ipad2 drops wifi connection when sleeping
ipad3 drops wifi connection 2013
my ipad drops wifi
new ipad dropping wifi connection
