Results 1 to 4 of 4
    14779
    Sep 2010
    daytona beach fl
    130
    Att air card and i-pad
    I have an ATT air card (usb) that I have used in my Lap Top for several years now and have paid ATT more that I would like to admit for it's use. The thing is a ATT 3g usb Sierra Connect card 881 module that has the small sim chip in it. Would it work in the I-Pad? ...Ethically? Legally?
    Jerry (the male component of jerliz)
    iPad Enthusiast!
    14540
    Sep 2010
    Regina, SK, CA
    40
    It ought to work... if you got a microsim. The minisims in most data sticks won't fit. You can trim them, but it's a finicky business and you can damage the SIM card. You'd have to configure your APN, etc. manually.
    As to ethics... such data plans tend to cost more than the iPad-specific plans so I don't see an ethical issue with it, personally.
    14779
    Sep 2010
    daytona beach fl
    130
    Real Noob in this area.
    Is it possible to convert an I-pad from the Wi-fi model to the 3g model simply adding the sim card I am presently using with my ATT Sierra card. Or do I need to buy a so called "3g" model up front. Then try to modify the card. And, I don't know whether I am up to that at this point either.
    Thanks for your patience. I was too embarrassed to ask any of my students as they already think they know it all. The problem is they let you know it.
    Jerry
    iPF Super Guru
    7401
    8 times
    Jun 2010
    4,240
    If you have a WiFi-only iPad, there is a little problem... there is no place to put the SIM card! (Plus it doesn't have the 3g circuitry)
    Nice try!
  1. 3 g sim card slot
    By Frankenstein in forum iPad Help
    Last Post: 04-21-2011, 04:15 PM
  2. Using sim card from Sierra wireless air card in ipad
    By Tonystewart02 in forum iPad Carriers
    Last Post: 11-20-2010, 08:44 PM
  3. SIM Card
    By CMFox in forum iPad General Discussions
    Last Post: 06-08-2010, 12:36 PM
  4. Got my Ipad(Sim card?)
    By skipper in forum iPad Help
    Last Post: 05-27-2010, 11:33 AM
  5. No more credit card?
    By Seadog in forum iPad General Discussions
    Last Post: 05-12-2010, 08:15 PM
air card for apple ipad
at&t wifi card for i pad
att air card for ipad
can aircard sim card be used in ipad
can i connect an aircard to an ipad
can you connect a ipad 4 with an air card
can you connect aircard to ipad 1
can you use a air card on a apple i pad
connecting an ipad to air card
connecting ipad to usb aircard
i need air card for ipad?
using sierra usb air card with ipad
