Calendar help please :)
This is a discussion on Calendar help please :) within the iPad Help forums, part of the Apple iPad Discussions category; I am struggling with what calendar app to use in order to be able to enter & view Google calendar events for our family on: ...
Results 1 to 5 of 5
    272400
    Jan 2013
    u.s.a.
    iphone or ipad (usually)
    PC (occasionally)
    Android phone to be purchased soon...(occasionally)
    I already synced using the CalenMob app from itunes but I seem to be missing events that are not going from one device to another or having duplicates show up too
    I have icloud and sync thru wifi
    97693
    498 times
    Sep 2011
    Michigan. USA
    15,231
    Quote Originally Posted by alm89
    PC (occasionally)
    Why don't you just use the google calendar and allow it to sync between all devices?
    272400
    Jan 2013
    u.s.a.
    I think I don't know what settings to have on/off on the iphone & ipad (that i just got) to do that. I experimented before looking at apps and must not have had it synced yet.
    97693
    498 times
    Sep 2011
    Michigan. USA
    15,231
    Ok-no problem.
    Go to your iPad settings - mail, calendar, contacts - calendar -turn ON.
    Make sure you turn on your calendar on your phone as well when you get it . Hope that helps.
    Also, then make sure in your calendar app, that you have checked off the google calendar.
    576 times
    Dayton, WA
    13,175
    If you have more than one Google calendar in your Google account and want it to sync to Calendar in iOS, you need to go here and enable it.
    https://www.google.com/calendar/iphoneselect
  1. Replies: 2
    Last Post: 11-15-2012, 02:30 PM
  2. iPad Calendar Not Syncing to Google Calendar on Android
    By danielgaz in forum iPad 3 Forum
    Last Post: 09-28-2012, 09:31 PM
  3. Replies: 3
    Last Post: 01-07-2012, 07:15 AM
  4. Replies: 4
    Last Post: 08-17-2011, 02:07 AM
  5. Ipad Ical calendar to google calendar sync issue
    By jduncan in forum iPad General Discussions
    Last Post: 07-22-2011, 11:26 PM
