Siri says wrong location
This is a discussion on Siri says wrong location within the iPad Help forums, part of the Apple iPad Discussions category; I just got a new iPad mini. But for some reason whenever I ask it my current location, or when the closest Indian takeaway is. ...
Results 1 to 10 of 14
    222598
    Jul 2012
    74
    I just got a new iPad mini. But for some reason whenever I ask it my current location, or when the closest Indian takeaway is. I keeps on saying I'm on Malvern hills. But when I go onto my apple maps, it's the perfect location. Can anyone tell me why it's saying this or how to change it.
    Thanks.
    222598
    Jul 2012
    74
    Also. If I say take me home. It says I Couldn't find an address for your contact but I have! Do you think I need to take it to the Genius Bar.?
    1522 times
    Walla Walla, WA
    15,430
    Hm.
    Go to Settings > Mail, Contacts, Calendars: Check under the Contacts section and make sure My Info is set to your own contact information. Make sure your street address is in that contact.
    Do the same thing for Settings > General > Siri.
    I'm not sure about the earlier problem, but it should fix the can't find address issue.
    222598
    Jul 2012
    74
    Quote Originally Posted by twerppoet
    Hm.
    Ok. The first problem is fixed now. But I checked what you said to do, and they've all got my name on it. But It won't find any ones addresses. Like if I say, what is the address for my dad, it says there is my address for this contact. But there is! If I say give me direction for London to Birmingham that works. Or if I say where do I live, it tells me that. Can you help please!?
    222598
    Jul 2012
    74
    Hm.
    If I say where does (any of my contacts) live, it tells me. But if I say, give me directions from my current location to (name of contact) I doesn't work.
    222598
    Jul 2012
    74
    Hm.
    Actually, I just did some testing. The only time it doesn't work if I say, take me to (name of contact) home. It says, I couldn't find a address for (name of contact) home.
    1522 times
    Walla Walla, WA
    15,430
    To find your dad (assuming you said 'dad'), it needs the relationship information in Contacts. You can either enter it using Siri, or directly in the Contacts app. To do so in Siri, you say something like "Darth Vader is my dad". To work "Darth Vader" must have a contact entry. This information gets added to your contact information under relationships.
    As for the rest, I've kind of lost track of what you are saying works and what does not work. If you'd list each non-working question and its incorrect response I might have a better idea of what is going on; or not.
    222598
    Jul 2012
    74
    I've already done all that. That works. With the retaliation-ship stuff. The only one that doesn't work is take me to dad home. Or like joe Robert home. It says I couldn't find an address for joe Robert home. But I do.
    1522 times
    Walla Walla, WA
    15,430
    I'm not sure what to say.
    Try opening the Contacts app and tap on the person's home address (make sure it's labeled as home). It should open in Maps. That will tell whether it's a map/address problem.
    The other possible problem is that Siri is not connecting the name's pronunciation with the Contact's entry. That sounds unlikely for the name you mentioned, but you never know. You can get around this by creating a phonetic entry in the Contact.
    To enter a phonetic name in Contacts:
    1) Open Contacts
    2) Choose the Contact
    3) Tap the Edit button.
    4) Scroll to the bottom and tap Add Field
    5) Tap Phonetic First Name
    6) Enter an alternate (or phonetic) spelling that's more likely to sound right, or try using Dictation to enter the name.
    7) Repeat 4 -6 for Phonetic Last Name.
    8) Tap Done
    Try Siri again to see what happens.
    That's all I can think of at the moment.
    222598
    Jul 2012
    74
    1) Open Contacts
    8) Tap Done
    Nope, none of that worked. But I tapped on the address and it worked. I think it's just the phrase I'm saying. All I'm saying is take me to (name of contact) and its ok cus I've got lots of other phrases that work. Like, where does (name of contact) live, or, give me directions from my current location to (name of contact). They all work. Thanks for all your help anyway.
  1. Contact pin (red), in wrong location on Google Map
    By dunmoanin in forum iPad Help
    Last Post: 06-14-2012, 06:07 PM
  2. Wrong Location
    By NicePad in forum iPad 1 Forum
    Last Post: 03-12-2012, 02:20 PM
  3. iPhone 4S Siri Video Demo, Using Siri For The First Time
    Last Post: 10-19-2011, 10:58 PM
how do i tell siri where my current location is on my ipad
ipad wrong location
siri give me the wrong location when i ask for a question
siri has wrong home address
siri on ipad locator wrong
siri tells me wrong location
siri wrong address for take me home
why does suri think my current location is wrong
