Problem with restoring
This is a discussion on Problem with restoring within the iPad Hacking forums, part of the Apple iPad Discussions category; Hey, I've a problem with restoring my iPad. Essentially, I'm running firmware 3.2.2 which I jailbroke with blackra1n quite some time ago. Anyway, I wished ...
Results 1 to 2 of 2
    256310
    Nov 2012
    Hey, I've a problem with restoring my iPad. Essentially, I'm running firmware 3.2.2 which I jailbroke with blackra1n quite some time ago. Anyway, I wished to restore my iPad back to 3.2.2 and basically get rid of the jailbrake.. with the intentions of then upgrading to the latest firmware. I had previously done this with an older ipod touch and thought the process would be quite similiar. Therefore, I downloaded the firmware 3.2.2 online and then tried to put my device into DFU mode in order to restore it. This is where I have the problem: it won't go into DFU mode and i keep getting the connect to itunes logo( i have tried numerous times to put it into DFU mode and it simply isnt working). Then when I try to restore the get the 3194 error that the device can't be restored. I'm on itunes 10.7 and am wondering what I'm doing wrong. Even when I disconnect the ipad from the computer i can't force restart it by holding down the home and power button and hoping to just turn it back on- it keeps bringing me back to the connect to itunes logo,i.e it's in recovery mode. I'm just wondering what can I do to fix this because at the moment the ipad is essentially "bricked" so to say. I'd really appreciate a helping hand, thanks!
    edit: I've actually managed to get it into DFU mode I think, however, I still get the 3194 error when I try to restore. Any help is appreciated. Thanks!
    155195
    3 times
    Jan 2012
    90
    I think your best bet is just to go to iTunes and do a Restore to the current version (since you are on 3.22 I assume means you have an iPad 1) which should be 5.11 for you. There is a sticky thread in this forum on doing exactly what you want to do.
    TUTORIAL - Failsafe method to restore the current version of IOS
  1. Restoring problem of IPAD 3 5.1.1
    By vahik777 in forum iPad Hacking
    Last Post: 09-09-2012, 05:03 PM
  2. Restoring problem..
    By RudyL90 in forum iPad Hacking
    Last Post: 01-22-2012, 08:01 AM
  3. Problem after restoring iPad to factory settings
    By ClarkIpad in forum New Member Introductions - Site Assistance
    Last Post: 01-18-2012, 05:00 AM
  4. Replies: 1
    Last Post: 02-02-2011, 12:05 AM
  5. [Last Thread I Promise] Problem restoring iPad
    By Adrenochrome in forum iPad Hacking
    Last Post: 07-20-2010, 01:42 AM
freaking ipad problem with restoring
problems restoring ipad3
