Results 1 to 10 of 16
    252749
    Oct 2012
    Malaysia
    8
    Cool Weird problems with IPAD 1 WiFi
    Hiya fellas,
    I've got a weird issue with my IPAD 1.
    My IPAD was originally running fine on a jailbroken IOS 5.0.1 and I decided to give it an upgrade to 5.1.1. So, as usual step prior to any JB upgrade, I'd turned off the device and put it into DFU mode. Only at this point I realized that I haven't backed up my IPAD. So, I turned it back on. This is when the problem happened. The IPAD seemed to be stuck on the Apple logo. After couple of days of tinkering (even letting the battery drained as some had suggested) it still turns on to the Apple logo and sits there.
    So, out of sheer frustration I've decided that I do not need to back up anything and straight away proceed to the upgrade segment. My IPAD can still be put into DFU mode but I have no idea why it will not get into recovery mode. Itune still recognizes it. Anyway, cutting to the chase, here are steps I've taken (which unfortunately DOES NOT resolve the problem):
    1. Used Itune to Shift+Restore a Custom IPSW (Error 1602)
    2. Used Itune to Shift+Restore a Custom IPSW with IREB R5 (Error 1602 and sometimes 1600)
    3. Used Itune to restore Official 5.1.1 IPSW (Error 1602)
    4. Used Itune to restore Official 5.0.1 IPSW (Error 3194)
    ** NOTE: During the Itunes restore process, it will verify the file against apple server (twice) at this point my IPAD would light up after the second verification process. But that's about it... It'll just light up the backlight only with nothing displaying on the screen.
    5. Used Redsn0w 0.9.6rc16 , 0.9.10b5c, 0.9.10b6, 0.9.12b1 & 0.9.13dev4 (No error but redsn0w freezes at "waiting for reboot" after "uploading second stage". At this point the IPAD lighted up its backlight only).
    6. Used TinyUmbrella's "Fix Recovery" and restart IPAD (Still freezes at Apple Logo).
    7. Used a different PC (freshly formatted) with same results as the above.
    8. Used 3 different USB cables (same results as above).
    I'm stumped and dead tired. Anybody got any suggestions besides having to purchase a new IPAD? Perhaps any other methods that I might have missed? Any help and suggestions here is highly appreciated.
    Thanks in Advance guys.
    Moderator
    131244
    729 times
    Dec 2011
    Regina,Canada
    15,091
    Quote Originally Posted by Achilles72
    Hiya fellas,
    If you follow the instructions in this tutorial exactly, you should end up with a functioning iPad 1 on iOS 5.1.1.
    TUTORIAL - Failsafe method to restore the current version of IOS
    252749
    Oct 2012
    Malaysia
    8
    Thanks for your reply scifan57,
    Anyway, I've gone through the tutorial and it's about the same with what I've done. I've got my ITunes updated to the latest version (v10.7). I've tried installing the IOS from my hard drive (I did mentioned Shift+Restore). I've tried Tiny Umbrella. I've also tried installing from a freshly formatted PC which would definitely have a fresh set of hosts file. All this were mentioned in the tutorial and I have tried them. I've wits end here. Been Googling and testing for more than a week now.
    Any other method(s) I should/could consider?
    Moderator
    131244
    729 times
    Dec 2011
    Regina,Canada
    15,091
    Did you try everything in the tutorial in exactly the same order as it is written? If you follow the tutorial exactly, with no shortcuts or missed steps, it will work and your iPad will be on iOS 5.1.1.
    BTW, you can't download iOS from a hard drive on your computer, only from the Apple servers.
    252749
    Oct 2012
    Malaysia
    8
    Quote Originally Posted by scifan57 View Post
    Hey there Scifan57,
    Once again thanks for your reply.
    Well, I did not follow the tutorial step-by-step per se. Nevertheless, I'm willing to give it a try. I'll follow the steps by the book.
    BTW, I didn't say I downloaded the IOS from my hard drive. I meant to say that I downloaded the IOS 5.1.1 from a link on this forum to my hard drive and did a Shift+Restore in Itunes.
    Anyway, I'll give this tutorial another try and will post back the outcome later.
    252749
    Oct 2012
    Malaysia
    8
    Ok, I've followed the tutorial to the letter... Twice. Once on my standard PC and the other on a freshly formatted computer. Unfortunately the outcome remains the same. Somehow the problem part here is when Itunes verify the file against Apple server for the second time, INSTEAD of the IPAD rebooting to the normal Apple logo with the progress indicator beneath it, my IPAD only lighted up its backlight.
    I believe that is the real culprit. My reason for saying this is that even on Redsn0w I will get the same thing after Redsn0w uploaded the second stage. My IPAD will only light up its backlight instead of the familiar pineapple logo with progress bar. Somehow this backlight issue stopped the USB connection henceforth the Error 1602 in ITunes. Which when I googled about would always seemed to be fixable by switching USB ports / cables.
    Now, does anyone else have this problem? Or is it just me? If anyone have any ideas and/or suggestions on how to go about this please help. I'm at wits end with this crap.
    Moderator
    131244
    729 times
    Dec 2011
    Regina,Canada
    15,091
    Have you thought of the possibility that your iPad has a hardware fault?
    252749
    Oct 2012
    Malaysia
    8
    The thought did occurs to me. I've got no quarrel with that. But being sort of a techie myself, I just can't put my mind at ease without knowing what exactly the problem is.
    I just can't understand why upon normal restart (by pressing the sleep/wake button) it'll go up to the Apple logo and get stuck there but from DFU mode and restore it wont get there? Just the backlight....
    How weird is this? right?
    13576
    803 times
    Aug 2010
    Western NY state (USA)
    9,447
    Sorry, but I don't have anything to add. I am only posting to tell you that I'm moving this over to the Hacking section of this forum. Hopefully, some of our "jail breakers" might have an idea what to do...
    Good luck.
    Fid
    Fid is offline
    116331
    19 times
    Oct 2011
    Hinterlands of Northern California
    415
    Greets! I had trouble with an iPod touch doing much the same thing. After many attempts I was able to get it into console mode with a list of error codes.
    I read through the fail safe instructions just now to see what they say. My trouble from a time ago had to do with step number 5. I ended up having to uninstall the anti-virus program all the way to get the restore to work. And I mean fully uninstall. I was a little spooked being naked on the Internet, but I did have the latest iOS already downloaded. After that the restore went without a hitch. Then I reinstalled the anti-virus suite. It was an adventure. Perhaps it will work for you.
    Sent from my iPad using iPF - Peace
    That upon which you dwell in the mind you become. - Lao Tsu
    iPad1 32GB, iPhone 4 - 32GB, iPod Shuffle
    1GB
  1. Weird 3g problems on new ipad working on ipad2
    By Calvin.baank in forum iPad Carriers
    Last Post: 04-02-2012, 11:02 PM
  2. Replies: 4
    Last Post: 12-28-2011, 09:37 PM
  3. iPad 1 wifi problems
    By Buckeyemania in forum iPad Help
    Last Post: 08-23-2011, 06:18 PM
  4. Weird Ipad2 WiFi Issue
    By McNewton in forum iPad Help
    Last Post: 07-30-2011, 04:09 AM
  5. Wifi is weird outside of home network
    By Dallasfoto in forum iPad General Discussions
    Last Post: 05-20-2010, 12:23 PM
how to upload file in ipad1 through wifi
ipad 1 problems
ipad 1 problems with wifi
ipad 1 wi fi problems
ipad 1 wifi issues
ipad 1 wifi problem
ipad 1 wifi problems
ipad1 problems
knowing my ipad1
problem liking to wifi on ipad1
problem with ipad 1
problems with ipad 1
Tags for this Thread
