Ipad format problem
This is a discussion on Ipad format problem within the iPad Hacking forums, part of the Apple iPad Discussions category; So here is my problem: I wanted to update my iPad to iOS 6 but it makes error. Then I knew it was from the ...
Results 1 to 10 of 20
Like Tree2Likes
Thread: Ipad format problem
    250270
    Oct 2012
    24
    Ipad format problem
    I wanted to update my iPad to iOS 6 but it makes error. Then I knew it was from the jailbreak, so I tried to format it from settings, but first it just freezed, then I turn it off then on again then I tried again, same freeze BUT THIS TIME, when I restarted my iPad and slide to unlock, it turned to safe mode. I respringed a lot of times but, same error. So I use safe mode at the moment but I can't use almost all tweaks or just cant modify any. So I know the answer will come with a PC but, I don't have PC at the moment and I remember that this happens in 5.1 and I was having PC but somehow I don't remember I fixed it without PC so please help.
    Edit: Uninstalling tweaks and hacks makes no use.
    167823
    16 times
    Feb 2012
    Brooklyn, New York
    322
    Get TinyUmbrella, connect your iPad, untick "Set Host to Cydia". Download the iOS 6 IPSW for your iPad, put your iPad into DFU, go to iTunes, shift+click Restore, select the stock iOS 6 IPSW and wait.
    iPhone 4S White 16GB iOS 6.1.2 || iPad 2 (Black) 16GB WiFi iOS 6.1.2 || iPhone 5 (Slate)/iPhone 4S (Black) 64GB Latest Beta/Full iOS
    iPhone Forums Moderator
    250270
    Oct 2012
    24
    First from where should I get tiny umbrella? Cydia? Safari? Second be a little illustrative if it means what I mean.
    13576
    745 times
    Aug 2010
    Western NY state (USA)
    9,287
    Ipad format problem
    Unfortunately, if your iPad is jail broken, you must use iTunes and a PC (or Mac) to upgrade to iOS 6. You can't do the over-the-air (OTA) install with a jail broken iPad.
    And - there is no other way. Sorry.
    250270
    Oct 2012
    24
    It's ok I just wana get out of safe mode some how so anyway?
    13576
    745 times
    Aug 2010
    9,287
    Ipad format problem
    To get the iPad out of Safe Mode, just reset it. To do:
    Hold both the power and home buttons until the screen goes dark and the Apple logo then appears (the slide to unlock screen may or may not appear). Once the logo appears, release the buttons. After a time, your homescreen will appear. Please note that it may take some time for the Apple logo to appear or for your homescreen to appear (or both). This is normal. Eventually, the homescreen will appear.
    That should bring it back to "normal."
    250270
    Oct 2012
    24
    Bad luck, didnt work...
    Moderator
    131244
    624 times
    Dec 2011
    Regina,Canada
    14,522
    Quote Originally Posted by BlackGun
    Have you seen this tutorial? If followed exactly, it will result in a functional iPad running the current version of iOS. In this case, iOS 6.
    TUTORIAL - Failsafe method to restore the current version of IOS
    250270
    Oct 2012
    24
    Nice but I don't have PC, remember? So I can't do even a single thing without a PC. Man, I think this is it...
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    Quote Originally Posted by BlackGun View Post
    Having a jailbroken device without access to a PC is not the best idea in the world
    You cannot ever update or restore a jailbroken iPad without access to a PC, just like you cannot jailbreak and iPad2 or iPad3 it in the first place without one. They are pretty essential.
    Your best bet is to borrow someone else's PC for 30 minutes. All they need is the latest iTunes installed. Nothing else. You won't mess up their setup in any way if you follow the guide posted above.
    scifan57 likes this.
  1. Video format (format, filesize, resolution) recommendations for iPad
    By bat0nas in forum iPad General Discussions
    Last Post: 02-16-2013, 09:43 AM
  2. Converting a text book into an Ipad format and/or kindle format
    By Johnplatero in forum New Member Introductions - Site Assistance
    Last Post: 07-18-2012, 02:02 PM
  3. Need Help about IPAD Format.
    By shaheengrouos in forum iBooks
    Last Post: 01-19-2012, 08:57 PM
  4. New problem: Movie format not supported
    By Jhenson18 in forum iPad Help
    Last Post: 01-05-2012, 01:40 AM
  5. Help with a rip from DVD to iPad compatible format
    By PhilipJFry in forum iPad FAQ
    Last Post: 12-22-2010, 09:02 PM
cant reformat ipad
format ipad problem
format jailbroken ipad
format jailbroken ipad 2
how to format jailbroken ipad
i cant format ipad
ipad cant format
page formatting issues on pages for ipad
reformat ipad
reformat jailbroken ipad
reformat jailbroken ipad 2
why i cant format my ipad
