need some help/advice (ipad 2 v4.3.3 jailbroken) - have searched forums already
This is a discussion on need some help/advice (ipad 2 v4.3.3 jailbroken) - have searched forums already within the iPad Hacking forums, part of the Apple iPad Discussions category; Hi, Iv'e searched the forums and need some advice and help. I have an ipad 2 on version 4.3.3 jailbroken, i would like to update ...
Results 1 to 3 of 3
Like Tree1Likes
  • 1 Post By Mickey330
Thread: need some help/advice (ipad 2 v4.3.3 jailbroken) - have searched forums already
    249041
    Oct 2012
    South Africa
    Question need some help/advice (ipad 2 v4.3.3 jailbroken) - have searched forums already
    I have an ipad 2 on version 4.3.3 jailbroken, i would like to update to 5.1.1 and then jailbreak it, cydis has the SHSH for 5.1.1
    is it possible to do this??
    Also, how do I transfer music from my ipad to my pc, its another music app, not the ipod app so going through itunes won't work.
    And lastly what happens if you sync a jailbroken ipad with itunes? Will it remove the apps that arent registered appstore apps, for example the superuser control panel app and activator (app that lets you decide what functions the buttons have).
    any help would be much appreciated
    Reaper
    13576
    1444 times
    Aug 2010
    Western NY state (USA)
    11,049
    Quote Originally Posted by Reaper1234za View Post
    Unfortunately, you cannot update your iPad2 at this time. We are waiting on tools to re-restore iOS 5.1.1 (supposed to work if if users have never upgraded to iOS 6). I don't know if those tools will let you upgrade to iOS 5.1.1 if you have the blobs. All I can suggest is to sit tight and wait for the release of the tools (and cross your fingers that it'll help you).
    If not, the only upgrade is to iOS 6, which may be a while to get jail broken...
    The only thing I can think to do is get a program (for your PC) called iFunbox. It's free and with it, you can access your iPad's system. So, you can go to the directory where your songs are and copy them over to your PC. That's what I'd do. Maybe someone else might have another suggestion.
    Reaper
    Nope. While iTunes shows Cydia icons as being on the iPad, it doesn't really "see" them. So, they won't be deleted when you sync. There really isn't any interaction between jail break tweaks and the App Store. As far as iTunes is concerned, you're not jail broken. So, it's perfectly fine to sync.
    Hope this helps.
    Reaper1234za likes this.
    249041
    Oct 2012
    South Africa
    Hmm, okay thanks a million, I do have the blobs so I'll just hang tight for a while.
    I'm busy downloading iFunBox right now - thanks for the advice.
    Okay sweet, need to sync, glad I wont lose my stuff. Thanks a million for all the help
  1. Replies: 4
    Last Post: 03-11-2014, 01:20 AM
  2. Not all my posts showing up when searched
    By snowbound in forum New Member Introductions - Site Assistance
    Last Post: 03-27-2012, 08:13 PM
  3. Replies: 4
    Last Post: 12-29-2010, 08:21 AM
  4. iPad is Now the UK’s Most Searched-For Apple Product
    By Maura in forum Apple iPad News
    Last Post: 12-08-2010, 03:05 PM
  5. Newly Jailbroken...need advice on apps.
    By Jazzephaye in forum iPad Hacking
    Last Post: 07-13-2010, 11:12 AM
how to update ipad from ver4.3.3
how to update jailbroken ipad 2 4.3.3 to 5.1.1
how to update my ipad2 version4.3.3 to 5.1
i have ipad v4.3.3
ipad v4.3.3
jailbreak ipad 2 v4.3.3 2012
update ipad v4.3.3 without losing apps
updating the ios on apple ipad 2v4.3
upgrade ipad 1 v4.3.3 to ios 5.1.1
upgrade jailbroken ipad 2 4.3.3 to 5.1.1
