Cydia Problems
This is a discussion on Cydia Problems within the iPad Hacking forums, part of the Apple iPad Discussions category; One Day.... My charger died and i tried to charge it it dosent open its stuck with logo screen ! I waste 1 hour to ...
Results 1 to 10 of 10
Thread: Cydia Problems
    132380
    Dec 2011
    55
    Cydia Problems
    One Day....
    I waste 1 hour to figure how to fix it and i did !
    Steps -
    1 - DFU Mod
    2 - Exit DFU Mod
    3 - Once You See The Apple Logo Screen Hold Power And Volume Up Button
    4 - keep Holding Till It Open It Takes Iike 30 Secounds
    After i did that
    ALL My Tweaks dosent work !
    But ifile works and some stuff
    My tweaks
    Pass code like android
    Lock info
    Sbsettings
    Soo many Stuff
    Reply If U know How To Solve This problem
    Device : iPad 2 ( Wifi )
    IOS : 5.1.1
    Jailbreak : absinthe 2.4
    yof
    yof is offline
    180717
    15 times
    Mar 2012
    EST
    162
    I have something simular to that for my iPhone 4 on 5.1.1 . Ran out of battery and stuck on DFU mode connect to iTunes. It was charging on the cord while appearing this, and I restarted it while charging on the cord. I had to unplug the charging cord and then restart it, and once it goes to lock screen I can continue to charge it. Weird eh?
    132380
    Dec 2011
    55
    Yes i want to solve that problem
    And Cydia Problem any one know how ?
    14571
    595 times
    Sep 2010
    Troon, Scotland
    7,046
    Cydia Problems
    What you are describing is a situation where you have loaded a tweak which is either not iPad compatible or not 5.1.1 compatible. You need to remove it from Cydia.
    Resetting the iPad and holding down the Volume Up key puts the iPad into SAFE MODE. In this mode, none of your tweaks will work, but you can use Cydia to remove the tweaks which are causing problems. You then reset your iPad again to see if your removed the correct tweak.
    Since you say you have too many tweaks to mention, then you will just have to try and remember which ones you installed last and remove those first. Anything which messes with the lock screen, particularly if designed for the iPhone, is a good candidate to remove.
    I am sure that this problem is nothing to do with the use of the charger that you mention. It is absolutely typical of installing an incompatible tweak.
    132380
    Dec 2011
    55
    I was looking in the internet they told me to install a file from ifile
    Var/Mobile/Doucument = cydia_1.0.3044-66_iphoneos-arm
    They told me to install : cydia_1.0.3044-66_iphoneos-arm
    I did atfer that i was trying to open cydia but cydia crash , when i open cydia it close right away
    Help?
    132380
    Dec 2011
    55
    Please Help me ! Reply!
    44796
    3 times
    Johannesburg
    254
    Cydia Problems
    Have you tried running jailbreak again? if you can't remember the last Cydia tweak you've installed.
    132380
    Dec 2011
    55
    I deleted few tweaks i think that was the last thing i ever download but i got another problem i cant open cydia it crash because i installed a thing cant u read up there 😠😖
    14571
    595 times
    Sep 2010
    Troon, Scotland
    7,046
    Well, I'm not sure which other website you get your advice from, but you have installed a very old version of Cydia onto your jailbroken device by following those instrucitons. cydia_1.0.3044-66_iphoneos-arm is a version for Cydia from 2010. It's no wonder it doesn't work on your device. Cydia has been completely re-written since then. Installing 1.0 won't fix any of your issues.
    The best course of action for you now is undoubtedly for you to restore and rejailbreak as there is no telling what you may have messed up and what needs to be fixed. Sorry, but that's the best advice you'll get. As you pointed out in a recent post of your own to another member , "You Should Restore it ( 100% Will Fix Your Problem )"
    132380
    Dec 2011
    55
    There is No Other Way That i can fix it Because i hate Download ipsw 5.1.1 its 1giga byte
  1. Cydia , Cydia apps , Safari / Problems
    By kinglingexe in forum iPad Hacking
    Last Post: 06-25-2012, 05:28 AM
  2. Cydia problems on iPad 2
    By Jaben2 in forum iPad Hacking
    Last Post: 08-07-2011, 03:15 PM
  3. Cydia winterboard problems
    By ivaninch in forum iPad Hacking
    Last Post: 04-26-2011, 05:35 PM
  4. Cydia problems...
    By Zach in forum iPad Hacking
    Last Post: 03-12-2011, 10:33 AM
  5. Problems with cydia apps
    By Dgreensuperhoops in forum iPad Hacking
    Last Post: 02-13-2011, 10:46 AM
cydia issues
cydia locked me out after battery died
cydia problem
cydia problems
cydia problems on ipad
cydia problems sep 2012
cydia wont open after jailbreak
cydia wont open on 6.0
fix apple logo stuck after open cydia on ipad 2 5.1.1
ipad 1 cydia problem
ipad 3 5.1.1 winterboard not working properly
winterboard not working on ipad 3 5.1.1
