HELP.. ipad apps not working ( not opening ) after jailbreak? what to do??
This is a discussion on HELP.. ipad apps not working ( not opening ) after jailbreak? what to do?? within the iPad Hacking forums, part of the Apple iPad Discussions category; HI.. need help... i have an ipad.. my friend already have installed games on it,like temple run .. but i jailbreak my ipad.. after i ...
Results 1 to 7 of 7
    236095
    Aug 2012
    Question HELP.. ipad apps not working ( not opening ) after jailbreak? what to do??
    HI.. need help... i have an ipad.. my friend already have installed games on it,like temple run .. but i jailbreak my ipad.. after i finish jailbreak.. i cant open my apps.. what should i do.. plz help.... tnx...
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    Please don't keep posting the same message all over the forums. Ask once, and please have patience until somebody answers you. I shall delete your other posts. Thanks for your understanding.
    Jailbreaking should not prevent you from opening your apps, however you can sometimes run into problems with permissions.
    1) fully reboot the iPad (power off, then back on again).
    2) if Temple Run will still not open, remove the app from the device (hold the icon, then press the cross that appears).
    3) Reinstall the app from the iTunes store. It should now run as normal.
    236095
    Aug 2012
    my apologies.. i'm so sorry.. and thank you..ahmm.. but all of my apps (games) install on my ipad is not working...? do i need to re-install all my games?? but thanks.. i will try to re-install the app..
    thanks again...
    and sorry...
    48665
    479 times
    Brisbane, Australia
    19,173
    Hi and welcome to the Forum!
    Hope you get those apps sorted.
    iOS5 Tips and Tricks
    Easy pictorial shortcuts & Helpful places. - For People new to the iPad.
    iPad 2 3G 64gb
    iPad 2 64gb 3G
    236838
    Aug 2012
    Ph
    hi i also have a problem with my Ipad, i recently jailbreak it. when i try to add new games from itunes, it does not sync. this is the second time i tried syncing new games from itunes to my ipad, the first one went well. but this times its not working.
    i am thinking to remove the jailbreak but wanted to consult you guys first, maybe you have a remedy to it. thanks in advance....
    129720
    18 times
    Nov 2011
    474
    Download Respring from Cydia and run it a couple times.
    236838
    Aug 2012
    Ph
    Quote Originally Posted by Redneck_Randy View Post
    will try this
    thanks a lot!
  1. Ipad opening apps itself and typing itself
    By ktmx in forum iPad Help
    Last Post: 02-20-2013, 04:47 PM
  2. Replies: 1
    Last Post: 12-29-2011, 09:43 AM
  3. IPad apps not opening
    By tvkklic in forum iPad 1 Forum
    Last Post: 11-18-2011, 10:01 AM
  4. Ipad 2 JB.. Working/non working cydia apps
    By Fluidz in forum iPad Hacking
    Last Post: 07-09-2011, 05:18 PM
apps not opening after jailbreak
apps not opening on jailbroken ipad
apps not working after jailbreak
apps not working on jailbroken ipad
ipad apps not working after jailbreak
ipad apps will not open
ipad jailbreak cant start app
jailbreak app not opening
jailbreak apps on ipad not installing
jailbreak ipad apps not working
my ipad is not working what do i do
pages not opening with jailbroken ipad
