Results 1 to 2 of 2
    234398
    Aug 2012
    Respring Problems
    Both my iPad 3rd gen and iPhone are jail-broken using the absinthe 2.0 and work perfectly fine.
    Only problem I seem to be having is that when I re-spring the SBSetting and Barrel apps appear on my springboard along with a few other miscellaneous things.
    Does anyone experience this issue?
    Also, sometime have iPad will just freeze when trying to re-spring....
    14571
    603 times
    Sep 2010
    Troon, Scotland
    7,059
    reappearing hidden icons are a sign that a component such as libhide is crashing. It's usually nothing to worry about but may be a sign of a badly behaving tweak, or just too many tweaks installed which are making use of the same library. A respring will always fix it until it crashes again.
    If it happens constantly, you probably need to weed out some tweaks (anything that messes with icons or the springboard) to see which one is behaving badly. Either remove ones you aren't using from Cydia, or disable them in SBSettings > More > Mobile Substrate Addons.
    iPhone5 32GB 6.1.2 (evasi0n) | iPhone4S 64GB 5.1.1 (absinthe) | iPhone4 32GB 7.0b (stock) | iPhone3G 16GB 3.1.3 (jbme) | iPod Classic 6G 160GB (stock) | AppleTV 2G 5.0.2 (seas0npass)
  1. need to respring after power on
    By ert6ic in forum iPad Help
    Last Post: 07-20-2012, 04:52 AM
  2. Respring Image?
    By HUNTER1 in forum iPad Hacking
    Last Post: 05-23-2011, 08:09 PM
  3. Respring errors?
    By tahjxmassakr in forum iPad OS
    Last Post: 12-22-2010, 04:13 PM
  4. respring putting 16 icons per screen instead of 20
    By grkhetan in forum iPad Hacking
    Last Post: 10-10-2010, 11:18 PM
  5. Respring my iPad
    By avivit02 in forum International iPad Users
    Last Post: 07-24-2010, 02:52 PM
fix ipad alway respring
how to respring ipad
ipad respring problem
is it bad to respring
is it bad to respring your ipad
respring freeze
respring problem
sbs settings freezes on respring
sbsetting respring freeze
sbsetting respring problem
sbsettings respring freeze
sbsettings respring problem
