ipad 2.2 (GSM model) restored with wifi firmeware, how can I fix it?
This is a discussion on ipad 2.2 (GSM model) restored with wifi firmeware, how can I fix it? within the iPad Hacking forums, part of the Apple iPad Discussions category; I accidentally restored iPad2,1_5.0.1_9A405_Restore to my GSM (ATT) ipad, how would I be able to get it back to GSM (2.2) based firmware, 5.0.1 or ...
Results 1 to 2 of 2
    155883
    Jan 2012
    I accidentally restored iPad2,1_5.0.1_9A405_Restore to my GSM (ATT) ipad, how would I be able to get it back to GSM (2.2) based firmware, 5.0.1 or 5.1.1 either is fine. I have shsh blob for both.
    I tried using DFU model flash, it says the 2.2 based firmware is not compatible
    it was my fault, I know it.
    14571
    632 times
    Sep 2010
    Troon, Scotland
    7,104
    It is not possible for you to flash the wrong IPSW to a device. It cannot be done by accident.
    You either have the wrong file downloaded for your device, a corrupt file downloaded, or you don't have a GSM model iPad2.
    When you go to Settings > General > About - What is the model number half way down?
    If you are sure it is an iPad2 GSM, the file you need for 5.1.1 is here - http://appldnld.apple.com/iOS5.1.1/0...6_Restore.ipsw
    If the message you are actually getting is that the device is not "eligible" that is a completely different thing. That is because you cannot install 5.0.1 due to SHSH Blob restrictions. Whether you have saved blobs or not is not the issue. You can't just try and restore 5.0.1 on an iPad2. It does not work like that. To be able to install 5.0.1 you would need to follow our tutorial here - TUTORIAL - Downgrade your iPad2 or iPad3 using SHSH Blobs and redsn0w (although you would be better advised to go to 5.1.1 and jailbreak that!).
    Hope that helps.
    iPhone5 32GB 6.1.2 (evasi0n) | iPhone4S 64GB 5.1.1 (absinthe) | iPhone4 32GB 7.0b2 (stock) | iPhone3G 16GB 3.1.3 (jbme) | iPod Classic 6G 160GB (stock) | AppleTV 2G 5.0.2 (seas0npass)
  1. Replies: 5
    Last Post: 04-06-2012, 11:29 AM
  2. iPad 2 wifi model
    By yakka6 in forum New Member Introductions - Site Assistance
    Last Post: 10-06-2011, 07:07 AM
  3. Ipad 16gb wifi only: can i add gps module to this model.?
    By alun101_uk in forum iPad General Discussions
    Last Post: 03-13-2011, 08:33 PM
  4. Should I buy a 16GB or 32GB wifi iPad model?
    By jazza in forum iPad General Discussions
    Last Post: 01-25-2011, 11:59 AM
  5. Wifi - Faster on Wifi model than 3G model?
    By mjeagent in forum iPad General Discussions
    Last Post: 06-11-2010, 12:13 PM
.shsh ipad 2,2 gsm 5.1.1
blobs ipad 2.2
gsm fix on ipad 2
how to restore ipad 2.2
i accidentally restored my ipad
ipad 2.2
ipad 2.2 5.1.1 blobs download
????? 2 ?????? 2.2
