Help, I'm stuck in safe mode.
This is a discussion on Help, I'm stuck in safe mode. within the iPad Hacking forums, part of the Apple iPad Discussions category; Have you tried going back to Cydia and reinstalling iFile? Once you uninstalled it/rebooted the iPad, maybe try again with the Cydia install? Did you ...
Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Like Tree1Likes
Thread: Help, I'm stuck in safe mode.
  1. #11
    13576
    743 times
    Aug 2010
    Western NY state (USA)
    9,272
    Have you tried going back to Cydia and reinstalling iFile? Once you uninstalled it/rebooted the iPad, maybe try again with the Cydia install? Did you use Cydia to UNinstall iFile? Sometimes, if you take it off yourself, without going through Cydia, you cause more problems for yourself. Hopefully, using Cydia to put it back on may re-load it right.
    Honestly, that's all I can think of. And, I think it is iFile that's messing you up. So, unfortunately, unless you can get iFile to "behave," I'm afraid you are facing a restore.
    Sorry, but I'm all out of options.
  3. #12
    223137
    10 times
    Jul 2012
    100
    Quote Originally Posted by Mickey330
    Hey Marilyn,
    I figured it out. It wasn't iFile or USB toggle switch, it was Bigify+. I had had a safe mode problem with the Bigify+ package once before too.
    For reference I went into SBSettings and went to Mobile Substrate Add-Ons and disabled everything then resprung. This took my iPad out of safe mode. Then I just had to isolate which package was causing the problem. So I figured out it was Bigify+ and removed it in Cydia. Now everything is back to normal.
    It might just be the package itself or might be because I use Shrink too and they conflict with each other, but either way there is an issue there that I have experienced twice now. I wasn't using it for anything permanent anyway, so it's ok I had to remove it.
    But no, I removed iFile in Cydia when I tried that. I didn't do it myself. I've reinstalled it since then, and like I said everything is back to working order.
    Thanks for trying to help.
    yof likes this.
  4. #13
    13576
    743 times
    Aug 2010
    9,272
    Whew! Glad you got it fixed.
    And yeah, I wouldn't run two tweaks together that do essentially the same thing (Shrink and Bigafy). Good pick on Shrink - that's one of my faves.
    And, thanks for highlighting the technique of disabling the Mobile Substrate items to figure out what was wrong. Not only is that a reminder to me for any other trouble-shooting problem (to ensure I recommend that), but it also may help someone else coming along with a Safe Mode problem. So, appreciate it.
    Again, yay!
  5. #14
    yof
    yof is offline
    180717
    15 times
    Mar 2012
    EST
    162
    Hey man that's very good news that you solved it! Good info!
    And that's even more exciting to see a USB Hub expansion for memory especially the games you talked about!
  6. #15
    223137
    10 times
    Jul 2012
    100
    Again, yay!
    Yeah it's handier than having to uninstall and reinstall all of your packages, when you can just disable them with like effect.
  7. #16
    223137
    10 times
    Jul 2012
    100
    Quote Originally Posted by yof
    Yeah the advantages I see in it are mainly two fold:
    1) You can connect multiple devices for transfer between them and your iPad.
    2) With an AC adapter you can mount drives that would normally be unmountable because of power limitations.
  1. Ipad keeps getting stuck in Safe Mode....
    By waffles07 in forum iPad Hacking
    Last Post: 07-08-2012, 05:52 PM
  2. Stuck in safe mode.
    By Llama Talks in forum iPad Hacking
    Last Post: 06-13-2012, 11:22 AM
  3. Stuck in Safe Mode...
    By Oddmanxx in forum iPad Hacking
    Last Post: 12-29-2011, 11:24 AM
  4. Stuck badly in it safe mode
    By Shihid in forum iPad Hacking
    Last Post: 08-09-2011, 11:58 AM
  5. Stuck in Safe Mode?
    By metheridge in forum iPad Hacking
    Last Post: 07-10-2011, 11:59 AM
can't exit safe mode ipad
exit safe mode ipad
exit safe mode on ipad
help i'm stuck in safe mode iphone
how to get ipad out of safe mode
igotya stuck in safe mode
ipad safe mode
ipad stuck in safe mode
safe mode on ipad
what is safe mode on ipad
why is my iphobe stuck on sucure mide on i gotya
