iPad 2 - Problem w/Belfry Tweak
This is a discussion on iPad 2 - Problem w/Belfry Tweak within the iPad Hacking forums, part of the Apple iPad Discussions category; I recently installed belfry to my jailbroken ipad 2 (5,1,1) but when i rebooted the springboard was broken, my iPad seems to think it's an ...
Results 1 to 3 of 3
    227495
    Jul 2012
    I recently installed belfry to my jailbroken ipad 2 (5,1,1) but when i rebooted the springboard was broken, my iPad seems to think it's an iphone :/ the lock screen looks like the one on the iphone, i can flip the ipad and the icons are the same size as the icons on the iphone.
    I have tried to unistall belfry, but it does not work. I can fix it by respringing 1-5 times, i want to fix it because it's really annoying.
    13576
    1457 times
    Aug 2010
    Western NY state (USA)
    11,071
    Quote Originally Posted by NOKIA0 View Post
    That behavior you see is the result of installing something on the iPad that is incompatible with the iPad or the iOS you're running (or both). So, the thing to do is to uninstall the latest tweak you put on - in your case, you already know which one...
    Are you saying that you can't uninstall the tweak from Cydia? Because that's the best way to take off a tweak from Cydia - go through Cydia to get it uninstalled properly (so that all stray bits of code are also cleaned up). Unfortunately, if you didn't get the tweak from Cydia, you probably won't be able to properly uninstall it. In which case, the only thing I can recommend is to restore and then re-jailbreak the iPad...
    As a side note, it states right in the tweak's description on Cydia that Belfry is only compatible with iOS 5.0 and 5.1 (it won't ever be supported on iOS 5.1), so may I suggest that once you get it off, don't put it back on your iOS 5.1.1-running iPad2. And, then - carefully read each tweak's description in Cydia to make sure it's going to work on an iPad or your iOS.
    Good luck.
    P.S. And, since you talk about a jail broken iPad, I've taken the liberty of moving your post over to the Hacking section. Thanks for your understanding.
    227495
    Jul 2012
    Quote Originally Posted by Mickey330 View Post
    Good luck.
    I have uninstalled belfry, but i have no idea about how to remove the remaining code.
  1. iKeywi HD for iPad - The new 5-Row Keyboard Tweak!
    By f4780y in forum Jailbreak Applications & Tweaks
    Last Post: 03-11-2014, 07:12 AM
  2. Belfry
    By Stevelamont in forum iPad Hacking
    Last Post: 07-23-2012, 03:45 PM
  3. Got a problem with SBVolume Tweak
    By peled in forum iPad Hacking
    Last Post: 08-12-2011, 01:53 PM
  4. Problem With Cydia Tweak Random Icon Flip
    By ssemmel in forum iPad Hacking
    Last Post: 08-10-2011, 07:15 PM
  5. iPad YouTube Tweak
    By rogatsby in forum iPad General Discussions
    Last Post: 06-30-2010, 01:32 PM
belfry 5.1.1
belfry cydia
belfry for ios 5.1.1
belfry ios 5.1.1
belfry ipad
belfry ipad 2 ios 5.1.1
belfry ipad 5.1.1
belfry not support ipad
Tags for this Thread
