Transparent Dock problem?! 5.1.1 ipad2
This is a discussion on Transparent Dock problem?! 5.1.1 ipad2 within the iPad Hacking forums, part of the Apple iPad Discussions category; Anyone has the same problem? The transparent dock tweak doesn't work, I've tried every "no dock" themes in Cydia, but none of them does the ...
Results 1 to 2 of 2
    205159
    May 2012
    Anyone has the same problem? The transparent dock tweak doesn't work, I've tried every "no dock" themes in Cydia, but none of them does the job
    13576
    751 times
    Aug 2010
    Western NY state (USA)
    9,313
    A couple of things to check. First, you are ensuring the theme is checked in Winterboard (and that you've respring the iPad)? Then, is the them above all the other checked themes in Winterboard? Winterboard has a hierarchal system in that the topmost checked theme will take precedence over the others.
    If all those are okay, then you may just have a theme that is not compatible with your iPad version or loaded iOS (or both). Apple changes the names of elements in every iOS and the names are also different depending on whether your define is an iPad 1, 2 or 3. Then, while some tweaks work on all devices, some are iPhone only. For themes especially (that don't change the file system - they just create an overlay) - the name of something is very important.
    Hopefully, some of this is of value and helps.
  1. Replies: 1
    Last Post: 04-11-2012, 12:38 PM
  2. Replies: 10
    Last Post: 09-07-2011, 05:18 PM
  3. Transparent black keyboard
    By ttipad in forum iPad Hacking
    Last Post: 08-09-2011, 11:17 PM
  4. Belkin transparent rear cover ...
    By the_john in forum iPad Accessories for iPAD 1, 2 and 3
    Last Post: 06-19-2011, 09:01 PM
  5. iPad stuck at apple logo and dock connector problem
    By spygrad2003 in forum iPad Help
    Last Post: 11-27-2010, 06:41 AM
cydia invisible dock
how come transparent dock tweak doesn't show transparency
ios 5 transparent pages
ios 5.1.1 transparent dock
ipad transparent dock
transparent dock ios 5
transparent dock ios 5 ipad
transparent dock ios 5.1.1
transparent dock ipad
transparent dock ipad 2
transparent dock ipad 3
winterboard transparent dock ipad
