Help - Lose 3G When Jailbreaking
This is a discussion on Help - Lose 3G When Jailbreaking within the iPad Hacking forums, part of the Apple iPad Discussions category; I have a big problem with my ipad 2, basically every time i jailbreak my ipad 2 5.1.1 (9b206) i lose my 3g network connection ...
Results 1 to 8 of 8
    216368
    Jun 2012
    london
    Exclamation Help - Lose 3G When Jailbreaking
    I have a big problem with my ipad 2, basically every time i jailbreak my ipad 2 5.1.1 (9b206) i lose my 3g network connection i have tried lots of things such as
    resetting network settings
    restoring then re jailbreaking
    restoring with custom ipsw then re jailbreaking
    using different tools to jailbreak like the latest absinthe and the latest redsnow
    and every time i do these methods i always set up as a new ipad as i thought maybe my old backup was corrupted
    none of these things are helping. Does anyone have any other ideas
    175844
    14 times
    Mar 2012
    Vancouver
    466
    Quote Originally Posted by kpbeats
    Make sure you have a backup of when it was Unjailbreaked that you can restore and not a backup that was made when it was on a previous jailbreak.
    Also try without a restore to make sure that your 3G works that will help narrow it down to the restore being the culprit.
    13576
    746 times
    Aug 2010
    Western NY state (USA)
    9,295
    Quote Originally Posted by kpbeats View Post
    When you had your jail break the first time, did you, at any time, have SBSettings installed and messed about with the 3G toggle?
    You may want to try again - but get SBSettings loaded. Then, play around with the toggle (turning it on/off, maybe with a restart in between).
    Sometimes, the setting really "sticks" - even if you remove the tweak and go back to stock.
    Is all I can think of to help. Good luck and let us know how you get on.
    P.S. Since you talk about jail breaking, I've taken the liberties of moving your post over to the Hacking section. Thanks for your understanding.
    129720
    18 times
    Nov 2011
    474
    I just had to rejailbreak my ipad 2 cause I lost 3G and all I could get was the Edge network. Not sure what caused it. Before I rejailbroke I deleted Cydia apps one at a time to see if one of them was the cause, no luck, still couldn't get 3G back. Did the same with Apple apps, still no 3G
    217027
    Jun 2012
    Quote Originally Posted by Redneck_Randy View Post
    Exactly the same thing happened to me a couple of weeks ago - I tried the same things but they didn't work and so I too had to restore and reJB. Restoring the backup from iCloud brought back the same problem with 3G disappearing, but fortunately I was able to do it again and restore from an earlier backup (which was whilst I was still JB). I don't think it was what Marilyn suggested that caused it. But it would be good to know what other reasons / solutions there might be - I was lucky it was still possible to JB as it could happen again outside of "the window".
    Any other suggestions as to what can cause this and how to avoid it short of a restore?
    267456
    Dec 2012
    17
    A friend had this problem on his jailbroken ipad 3 few days ago.. Tried to re-restore & re-jailbreak again but still could not get the 3g signal.. All the signal he receives was the edge network & 'circular logo' network everytime..
    Went to Apple care centre & the care centre guy told that an ipad would not likely have a signal problems.. It would either be sim slot unable to read sim card, faulty sim card or service provider having technical issues..
    Went to the service provider, changed into a new sim card but still couldn't get the 3g signal.. The service provider guy even take the initiative to try his own sim card & put it on the ipad but yet still no 3g signal..
    My friend then call me up saying he wanna borrow my ipad which is a stock ipad 3 on ios 6.0.1.. He then placed his sim card on my ipad intending to experiment which is causing the faults & few minutes later a message pops out..
    CARRIER SETTINGS UPDATE message.. Installs it & managed to get 3g on my ipad..
    Took out his sim card & put it back on his ipad & finally he managed to get the 3g signal till today?
    Maybe this helps, maybe it does not.. Hopefully it helps..
    Also I noted that his Sim card carrier is different when slot into his ipad & my ipad which is indicated with the yellow arrow in the picture..
    Attached Thumbnails Attached Thumbnails Help - Lose 3G When Jailbreaking-image-1078276047.jpg   Help - Lose 3G When Jailbreaking-image-3998912929.jpg
    270243
    2 times
    Jan 2013
    101
    I also had a,problem with 3 g, new to the forum and tried to post my thread to you, with no avail, anyway FID helped me by having me reprovisitioning my account. Look for the thread about 3G problem. Dated 2 jan I think. Good advice in this forum.
    Good Luck
    76661
    4 times
    Jul 2011
    Oregon
    272
    I had that problem with my Verizon iPhone about a year ago. I removed Mobile Substrate and re-installed it, and the 3G came back. One thing EVERYONE who has this problem might try BEFORE removing the OS and reinstalling/rejailbreaking is to put the device in safe mode (Hold the volume up button down while rebooting) and see if the 3g comes back. If it does, then I'm not sure of the next best procedure, but I'll be it's a lot less painful than wiping the thing and reinstalling/rejailbreaking.
    Brian
    (sent from my iPad)
  1. How did I lose almost all my money being attacked?
    By saholz in forum Modern War Forum
    Last Post: 05-16-2012, 03:22 PM
  2. Will I lose?
    By SusanR in forum iPad OS
    Last Post: 10-15-2011, 01:02 PM
  3. Lose purchased movies.
    By Hopdevil in forum iPad Help
    Last Post: 09-22-2011, 03:06 PM
  4. Don't want to lose apps
    By GrumpyOldFart in forum iPad Help
    Last Post: 08-28-2011, 09:11 PM
  5. You laugh, You lose
    By scotty frank in forum Off-Topic
    Last Post: 02-01-2010, 01:40 PM
3g loss after jailbreak
ipad 3 losing 3g after jailbreak 5.1.1
ipad 3 no 3g after jailbreak
ipad edge only after jailbreak
ipad jailbreak 3g
jailbreak 5.1 3g connection problem
jailbreak 5.1 3g problem
jailbroken iphone 4 no 3g reception
lost 3g with jailbreak
lost my 3g connection iphone 5 after jailbreak
lost network with jailbreak
no 3g on ipad 2
Tags for this Thread
