Help!! Stuck in lockscreen loop Ipad1 5.1 redsn0w JB
This is a discussion on Help!! Stuck in lockscreen loop Ipad1 5.1 redsn0w JB within the iPad Hacking forums, part of the Apple iPad Discussions category; So it all worked great, tethered didnt bother me, but spaced on the backups and ssh. Now something is causing a respring at the lock ...
Results 1 to 4 of 4
    189673
    Apr 2012
    La Verne CA
    So it all worked great, tethered didnt bother me, but spaced on the backups and ssh. Now something is causing a respring at the lock screen every 4 seconds or so. I can go to recovery mode and re-JB, but it stays the same, and if I try to restore with itunes I get either an error 2003 or 2005 and it aborts the restore. Is there anyway to erase the cydia apps, or force a restore? My wife is gonna be pissed if I screwed up her ipad. Any help is appreciated.
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    Do you have intelliscreenX installed? If you have anything which messes with the lock screen you MUST ensure you reboot tethered every time. That's not the same a re-jailbreaking which WONT work. If you don't you will get a respring loop.
    redsn0w > Extras > Just boot.
    And don't panic. You cant mess up the iPad. It can always be recovered.
    If it is still respringing when you are sure you did a tethered boot (i.e. you saw the pineapple logo when it booted) then let us know.
    189673
    Apr 2012
    La Verne CA
    Yep...still stuck. I can do just boot, it loads kernel, i can get the pineapple, then back to the loop. I have tried restoring, but I still get a code 2003.
    189673
    Apr 2012
    La Verne CA
    Nevermind. Next time i wont get my stock usb 30 pin and my cheap one mixed up. Makes all the difference in the world...
  1. Stuck in DFU loop following downgrade
    By explody in forum iPad Hacking
    Last Post: 11-04-2011, 04:07 PM
  2. Clean update but Stuck in Recovery loop
    By yeheey18 in forum iPad Help
    Last Post: 10-07-2011, 01:51 AM
  3. Replies: 6
    Last Post: 09-25-2011, 05:46 PM
  4. Ipad1 4.3.5 jailbreak with redsn0w
    By Ashenone in forum iPad Hacking
    Last Post: 08-09-2011, 05:53 PM
  5. iPad1 stuck in recovery loop FW 4.3.3
    By maim in forum iPad Hacking
    Last Post: 06-03-2011, 12:34 PM
can you tether boot on recovery loop ipad
ipad stuck at lock screen
ipad stuck in respring loop
iphone 3gs stuck in lock screen then respring
iphone 4 stuck on pineapple screen ios 5.1
iphone 4s respring loop passcode lock
iphone lockscreen loop
ipod stuck in respring without lockscreen
itunes error 2003
jailbroken iphone 4 stuck on lock screen loop
logo lock screen loop
stuck on lock screen after jailbreak
