What exactly does memory tap do?
This is a discussion on What exactly does memory tap do? within the iPad Hacking forums, part of the Apple iPad Discussions category; Hey guys. Here is a question for some users that are more tech savvy than I am. I recently jailbroke my iPad and have been ...
Results 1 to 10 of 13
    9170
    Jul 2010
    West Lafayette, IN
    8
    Hey guys. Here is a question for some users that are more tech savvy than I am. I recently jailbroke my iPad and have been enjoying the ability to multitask using backgrounder, activator, and proswitcher. I also have been using circuitous. I have noticed that some apps use up a lot of ram and cause apps to stop backgrounding. For example, Pandora usually crashes after awhile if I am running it in the background. Will memory tap from cydia help with this? If yes, how does it work and is it safe to use?
    Also, has anyone out there "supercharged" the iPad? I know people have done this with iPhones, but I don't know if it is possible for the iPad also?
  2. #2
    iPad Enthusiast!
    8915
    Jul 2010
    Michigan
    39
    Memory freeing applications generally flush out any non-executing memory and sometimes close out backgrounded applications. That's pretty much what that app does.
    Sincerely,
    Steve Bostedor
  3. #3
    9170
    Jul 2010
    West Lafayette, IN
    8
    Okay, thanks for the reply. Is there any control over witch background applications are closed?
  4. #4
    iPad Enthusiast!
    8915
    Jul 2010
    Michigan
    39
    Not in any of them that I've seen.
    Sincerely,
    Steve Bostedor
  5. #5
    3851
    16 times
    May 2010
    Miami, FL
    2,336
    the apps like this go in and clear out memory that it thinks is not being used or needed. When background apps die after running a memory freeing app they stop running not because memory app closed them. They stop because the memory app removed some of the memory that they were actually using and then the app crashed.
    These type of apps are good if you have an app with a memory leak, where over time the one apps just starts to eat up all the memory of the device even after the app has been closed. You could then regain the lost memory space.
  6. #6
    iPad Enthusiast!
    8915
    Jul 2010
    Michigan
    39
    yep - nothing that can't be done with a simple respring or reboot.
    Sincerely,
    Steve Bostedor
  7. #7
    9170
    Jul 2010
    West Lafayette, IN
    8
    Thanks for the feedback guys. I went ahead and downloaded memory tap. When I free up memory I have seen increases in available memory up to 30 MBs or more. It has turned out to be useful if I want to background an additional app without crashing a running one. BTW Steve, love the show.
  8. #8
    3851
    16 times
    May 2010
    Miami, FL
    2,336
    Quote Originally Posted by rjleamaster View Post
    SBSettings has the same feature to free memory.
  9. #9
    iPad Master!
    1491
    Mar 2010
    NW New Mexico
    545
    I guess my question would be - are people having issues running out of available memory? I do a complete power off every day - and I've never ran into an out of memory message that I know of.
    Most probably tapped on my iPad!
  10. #10
    3851
    16 times
    May 2010
    Miami, FL
    2,336
    Quote Originally Posted by DavidNM View Post
    No you shouldn't. Its more for if you have apps that waist memory and have memory leaks.
    if an app has a memory leak the memory slowly gets used up and once the app closes that memory is not freed up for new apps to use.
    Rebooting would have the same effect as running a app to free memory.
Sponsors
  1. Low Memory!! Is there an app for that?
    By stever in forum iPad Apps
    Last Post: 06-09-2011, 10:17 AM
  2. USB memory stick.
    By olsen in forum Off-Topic
    Last Post: 06-30-2010, 04:11 AM
  3. Apps and memory
    By Dixonyy18 in forum iPad General Discussions
    Last Post: 06-13-2010, 10:12 PM
  4. Device low in memory!
    By deoknam in forum iPad Help
    Last Post: 06-10-2010, 05:24 PM
  5. Not enough memory available...
    By Matth3w in forum iPad Help
    Last Post: 05-27-2010, 06:42 PM
app memory usage cydia
cydia memory
cydia memory app
cydia memory tap
cydia memorytap
does memory tap work
how do u work memorytap from cydia
how does memory tap work
how memory tap works
how to use memory tap
how to use memory tap on cydia
how to use memorytap
memory tap
memory tap app
memory tap cydia
memory tap ipad
memory tap not showing in activator
memorytap
memorytap cydia
what is memory tap on cydia
Tags for this Thread
