Very odd problem?
This is a discussion on Very odd problem? within the iPad Hacking forums, part of the Apple iPad Discussions category; Hey guys I have a very odd problem. My iPad 2 battery went dead today. So I put it on the charger. I just got ...
Results 1 to 9 of 9
    44242
    iceman72@gmail.com
    30
    Very odd problem?
    Hey guys I have a very odd problem. My iPad 2 battery went dead today. So I put it on the charger. I just got it off the charger and now it seems to be stuck in some iPhone looking mode. I can run apps but i can't type anything once they are open because they go sideways. I tried to run winter board to respring but once in apps i can't do anything. I am running OS 5.0.1 and its jailbroken. Anyone have any ideas how i can fix this? Everything on the screen is all out of whack. All my icons seem to be off and some vertical rows are like close side by side. I am lost. Also it won't change views when i flip the iPad either. No idea what I did to cause this. Thanks in advance for your help.
    139850
    20 times
    Dec 2011
    Denver, CO
    639
    You may do some more research but it looks like you may have to do a full restore and kill the jailbreak. Before though do a full soft and hard reset to see if that works so you don't have to loose your JB.
    iPhone 4s 64GB White (Jailbroken), The "New iPad" 16GB Black (Stock), Past devices: iPad 2, HTC Hero, HTC Evo, HTC Evo 3D, ASUS Transformer.
    44242
    iceman72@gmail.com
    30
    it sucks because i have soft and hard reset several times and nothing.
    44242
    iceman72@gmail.com
    30
    is there a way to respring from my iMac?
    44242
    iceman72@gmail.com
    30
    I am no where near an apple shop.
    139850
    20 times
    Dec 2011
    Denver, CO
    639
    Quote Originally Posted by wushuangpu View Post
    Go to the Apple shop and find someone help
    No good...They will likely not work on it for you since it is jailbroken...Do you have sbs settings in cydia? Try respring from that. If not you prolly need to do a restore....
    48665
    479 times
    Brisbane, Australia
    19,159
    I'll just transfer this thread to our Hacking section. Good luck!
    iPad 2 64gb 3G
    179010
    20 times
    Mar 2012
    537
    I haven't jailbroken for a while but I would say play around in winter board as two might be conflicting I'm not sure if it's changed much since iOS 3 but some was buggy as hell. Just a suggestion? Good luck.
    13576
    744 times
    Aug 2010
    Western NY state (USA)
    9,278
    This type of behavior usually occurs when you install a tweak from Cydia that isn't compatible with the iPad.
    Can you get the iPad into Safe Mode? Cause you want to get back to Cydia an uninstall the latest tweak(s) you put on. Once you remove it/them, the iPad should then respring back to normal (or you can come out of Safe Mode and it'll look normal). Then, you can either go through a trial and error process to see which tweak it was that caused the issue, or swear that you'll never use that tweak again.
    The key here is, if you can't get to Cydia by just pressing the icon, is getting it into Safe Mode. So, try that and see how it works. Good luck and let us know how you get on.
  1. Replies: 20
    Last Post: 09-07-2011, 07:59 AM
  2. Garageband problem or ipad2 touchscreen problem?
    By Summy73 in forum iPad Apps
    Last Post: 06-02-2011, 05:35 PM
  3. 4G problem for GPS
    By Seadog in forum iPad General Discussions
    Last Post: 02-09-2011, 10:12 PM
  4. Wi-fi problem
    By Simonj in forum iPad Help
    Last Post: 10-10-2010, 09:00 PM
i am me and i wont change for anyone wallpaper
ipad 2 odd
ipad 2 respings on charger
ipad 2 respringing after dead battery
ipad 2 winterboard problem
ipad just went dead
ipad went dead
what happen if i can't get on cydia and it suck on safe mode
