Still having problem with my JB on ipad2 wifi GSM....
This is a discussion on Still having problem with my JB on ipad2 wifi GSM.... within the iPad Hacking forums, part of the Apple iPad Discussions category; Just decided to do my 1st JB on my iPad2 yesterday morning, after download and unrar the Absinthe win v0.4 on to my window 7. ...
Results 1 to 10 of 10
    93541
    Aug 2011
    8
    I did as instruction shown :
    1) I start the application.
    2) connect my ipad2 with USB. ( I already did a backup with the itunes but not restore, coz of iOS 5.1)
    3) Absinthe detected iOS 5.0.1 (9A405) and I click the JB button.
    4) small blue bar shown up to indicate the progress of JB, it state that the JB work will take some time.... So wait...
    Ok, so I just left it as it is.... But after 2 hours of time pass and it still remain as before, no progress on the blue bar indication... I open the Task Manager and the status shown that Absinthe still Running... I leave it for another 3 hours, and it still the same...
    So it was me or did anybody having the same issue too???
    Any advise and help are very much appreciated, (BTW, I did try it again this morning but still no luck... Sigh...)
    Regards and have a nice day.
    Jeff
    14571
    632 times
    Sep 2010
    Troon, Scotland
    7,104
    You must run Absinthe with Administrator privileges on Windows7. You may also have to set compatibility mode for Windows XP SP 3 by right clicking on the EXE before you run it..
    Also, how much data is on your iPad? The Absinthe vulnerabilities use the backup and restore mechanisms on the iPad. If your iPad is 64GB and full it will take several hours to complete. You must also have enough hard disk space on your PC to take the backup, pwn it, then restore it again. It could be many GB in size if you have lots of data on your device.
    iPhone5 32GB 6.1.2 (evasi0n) | iPhone4S 64GB 5.1.1 (absinthe) | iPhone4 32GB 7.0b2 (stock) | iPhone3G 16GB 3.1.3 (jbme) | iPod Classic 6G 160GB (stock) | AppleTV 2G 5.0.2 (seas0npass)
    93541
    Aug 2011
    8
    Quote Originally Posted by f4780y
    Thanks bro for the prompt replied~
    I have ipad2 32GB and 21GB of my storage have been used... I know the data is big but dare not restore it coz afraid this will automatically update me to iOS 5.1...
    Maybe this is my problem... (btw I did use Administrator on Absinthe, used compatibility mode for XP SP 3 and have 40GB free hard disk space left on my PC.)
    I think I will have to live with it without JB for the time been... Sigh...
    Anyway thanks again bro for the explanation~
    Regards,
    Jeff.
    172732
    9 times
    Mar 2012
    334
    Are you connected to the internet while running the jailbreak?
    93541
    Aug 2011
    8
    Quote Originally Posted by Semel
    Yes sir, with my Internet connected while JB....
    93541
    Aug 2011
    8
    Quote Originally Posted by ongjeff2002
    Will this affected my JB?
    172732
    9 times
    Mar 2012
    334
    Not sure with the new jailbreak.Could be.Anti virus software running could also affect jailbreaking
    93541
    Aug 2011
    8
    Thanks ~
    13576
    1445 times
    Aug 2010
    Western NY state (USA)
    11,053
    Maybe try deleting everything off your iPad? As in, remove all your apps (and thats the only thing - don't reset it or anything). Don't make another backup, cause you'll want to put the iPad back as it was, whether the jail break worked or not.
    Then, there'll be less "stuff" for Absinthe to have to work with/sort through...?
    Now, couldn't tell you if it would make any difference, but if you've tried everything else (and followed all the set-up directions for your computer). You won't hurt anything...
    Sorry you're having troubles.
    93541
    Aug 2011
    8
    Quote Originally Posted by Mickey330
    Thanks for the advice~
    Agreed, must be my apps delay the JB process... Will try to delete some of it.
  1. Ipad2 wifi problem
    By regina_phil in forum iPad 2 Forum
    Last Post: 12-23-2011, 11:17 PM
  2. problem with WiFi
    By diannenet in forum iPad Help
    Last Post: 07-07-2011, 06:07 PM
  3. Replies: 3
    Last Post: 06-04-2011, 08:16 AM
  4. Garageband problem or ipad2 touchscreen problem?
    By Summy73 in forum iPad Apps
    Last Post: 06-02-2011, 05:35 PM
  5. Replies: 1
    Last Post: 06-02-2011, 03:12 PM
download wifi hack to ipad 2
ipad 2 jailbreak 5.0.1wifi fix
ipad 2 wifi issues
ipad 2 wifi problems
ipad 2 wifi problems 5.0.1
ipad 2 wifi problems 5.1
tools wifi hacking ipad2
wifi hack for ipad 2
