Need help to fix a little problem...
This is a discussion on Need help to fix a little problem... within the iPad Hacking forums, part of the Apple iPad Discussions category; I have install a cydia tweak, and now my Ipad 2 is stuck at the Apple boot up screen (AGAIN...!) Is there anyway to get ...
Results 1 to 5 of 5
    135900
    Dec 2011
    75
    Is there anyway to get into the Ipad from my PC?
    I have OpenSSH install, but dont know if I can use that, when the Ipad is stucked at the boot up screen?
    Med venlig hilsen
    Emil
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    It depends at what point the device is stuck. If you can see the "spinning wheel of death" at any stage, that is a great indication that you will be able to SSH onto the device.
    But if the device is stuck early in the boot process then you don't have much chance, sorry. In this scenario you may be forced with a restore, which could mean the end of your jailbreak!
    I have just tested the 5.0.1 window and Apple are still signing 5.0.1, but the window could close any minute. 5.1 was released yesterday and the signing window for a previous firmware normally closes between 24 and 48 hours after release. You have very little time left to restore to 5.0.1, and you will need to do it manually be downloading 5.0.1 from our sticky thread and using the shift-restore method in iTunes to select the firmware file you downloaded.
    Good luck.
    I'm also gong to move your thread into the main hacking section, OK?
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    Just tested again, and the window is closed, so if you didn't manage to restore to 5.0.1 you are now out of luck, sorry. Any restore you do must be to 5.1.
    135900
    Dec 2011
    75
    Thank you very much... I restored it with 5.0.1 and im jailbroken again... Thank you
    14571
    596 times
    Sep 2010
    Troon, Scotland
    7,049
    glad you made it before the window closed.
  1. I am new here and I have problem!!
    By AmgedIsmail in forum New Member Introductions - Site Assistance
    Last Post: 02-13-2012, 08:19 PM
  2. 5.0.1 problem
    By Tripmaker in forum iPad OS
    Last Post: 01-01-2012, 01:02 PM
  3. Replies: 20
    Last Post: 09-07-2011, 07:59 AM
  4. Garageband problem or ipad2 touchscreen problem?
    By Summy73 in forum iPad Apps
    Last Post: 06-02-2011, 05:35 PM
  5. HELP Big Problem
    By Dee Ashley in forum iPad Help
    Last Post: 05-25-2011, 03:44 PM
fix spinning wheel of death ipad
how to fix spinning wheel of death ipad 1
ipad jailbreak spinning wheel
ipad spinning wheel
ipad stuck on spinning wheel
ipad stuck spinning wheel
ipad2 wheel stucked cydia
iphone 4s spinning wheel
iphone 4s spinning wheel of death
iphone 4s stuck on spinning wheel
jailbroken ipad 2 stuck on spinning
jailbroken iphone 4s stuck on spinning wheel
