Modding on iOS 5.0.1 [help]
This is a discussion on Modding on iOS 5.0.1 [help] within the iPad Hacking forums, part of the Apple iPad Discussions category; Hey,So recently I have updated my iPad 2 and now my themes aren't functioning properly. I am aware that some file name changes have been ...
Results 1 to 7 of 7
    168299
    Feb 2012
    Canada
    Talking Modding on iOS 5.0.1 [Solved kinda]
    Hey,So recently I have updated my iPad 2 and now my themes aren't functioning properly. I am aware that some file name changes have been applied to various files and such. Is there a thread which informs us what file names/extensions which have been applied?Okay so basically, I would like my iPad theme to show a different wallpaper on each page and no name extensions or rename I've tried so far have worked. Also I was able to change the slider but the slider bar remained the gradient grey, I would like to make it transparent.So if anyone can link me or guide me with this issue, I would very much appreciate it.
    That's the grey gradient I'm unable to find or haven't been able to rename correctly. Does anybody know the directory location for this file and/or the correct name of the file?Also I've been told to rename the separate wallpapers I desire to "Page0.png, Page1.png etc.." but this hasn't worked even though they're in my theme folder. Am I missing "~ipad" in the file name or some other extension I am unaware of?
    __
    Okay so thanks to the responses I was able to remove the bar by creating two files, WellLock~ipad.png and WellLock@2x~ipad.png which are transparent with dimensions, 27 x 52 and the other 54 x 104. Adding these files to your customized theme will remove the gradient.
    The issue with different wallpapers each page is still unsolved as the PerPage tweak applied the images but in iPhone size .
    Again, Thanks for the help
    167823
    16 times
    Feb 2012
    Brooklyn, New York
    322
    /var/root/Library/Themes or /var/root/stash/Themes. I believe it's the latter iirc. I don't have my iPad on me so I can't check it for you unfortunately.
    iPhone 4S White 16GB iOS 6.1.2 || iPad 2 (Black) 16GB WiFi iOS 6.1.2 || iPhone 5 (Slate)/iPhone 4S (Black) 64GB Latest Beta/Full iOS
    iPhone Forums Moderator
    Banned
    12904
    34 times
    Aug 2010
    Raleigh, NC USA
    3,655
    Willer gave the destination of where the themes should go.
    Which is var/stash/themes.(whatever).
    No, there isn't a thread of the changed stuff, but if you are looking for the slider thing, look for a folder called "telephonyUI". All the lockscreen stuff is in there.
    13576
    743 times
    Aug 2010
    Western NY state (USA)
    9,278
    I believe the names you are looking for are:
    You also might want to look at bottombarbkgnd.png and BulletWellLock.png. I'm not sure cause its been a while since I themed the slider...
    They can be located on your iPad at this iFile address: /System/Library/PrivateFrameworks/TelephonyUI.framework/
    What I suggest is that you create transparent PNG images, name them the above file names (remember that case is important) and them put them into your current theme. You'll probably need to make new folders, but the end result should look like this:
    [YourTheme].theme/Bundles/com.apple.TelephonyUI/[the PNG images]
    Then, respring and that shadow should be gone.
    As far as putting a separate wallpaper on each Springboard page, you'll need a tweak called PerPageHTML (free) or PerPageHTML+ (paid). I never could get either to work, but it's the only thing I know that will put separate wallpapers in your iPad. Sorry.
    Hope some of this helps. Let us know how you get on.
    168299
    Feb 2012
    Canada
    Well thank you guys for your replies, I shall test them right now and let you know which works.
    It worked! . The component was the WellLock~ipad. It took a while because i had to find the dimensions and then create a second one called WellLock@2x~ipad.
    I'll post up pictures once I'm done trying the PerPageHTML which I'm fairly sure is going to work :3
    Thanks Again to willerz2, graywolf and of course Mickey330.
    13576
    743 times
    Aug 2010
    9,278
    Hurray!
    Glad we could help. Sorry about PerPageHTML - but sometimes, tweaks are only for the iPhone/iPod (not too many developers have iPads, even now).
    168299
    Feb 2012
    Canada
    Nah, Thats cool. Just hope there will be lots of developer teams for the iPad soon .
5.0.1 slider change
apple ipad wallpapers ios 5.0.1
bottombarbkgnd on ios5
how to remove slider background ios 5
ios 5 slider size
ios 5 wallpaper
ios wallpaper file location
ios5 multiple wallpaper for ipad
iphone welllock image
remove wallpaper gradient ios 5
remove wallpaper gradient ios5
transparent background ios
Tags for this Thread
