Need some help
This is a discussion on Need some help within the iPad Hacking forums, part of the Apple iPad Discussions category; Like an idiot I deleted my calendar file on iPad 2. Can some please upload the com.apple.mobilecal file for me for iPad 2. Thx much ...
Results 1 to 6 of 6
Like Tree1Likes
  • 1 Post By Mickey330
Thread: Need some help
    65353
    Jun 2011
    Los Angeles
    11
    Need some help
    Like an idiot I deleted my calendar file on iPad 2. Can some please upload the com.apple.mobilecal file for me for iPad 2. Thx much appreciated. FYI I have spent an hour looking on google already for it or wouldn't be asking. Thx
    97693
    858 times
    Sep 2011
    Michigan. USA
    18,178
    Hi there-are you referring to the native calendar app on the iPad? Not sure how that can be deleted if that is the case. Have you tried to restart or reset our iPad? Perhaps by doing that it may reappear.
    Also, have you tried to sync your iPad? That may also be worth a try as well.
    65353
    Jun 2011
    Los Angeles
    11
    I have not synced it yet (which I'm hopping it will reinstall on its own) iPad synchs with office computer. As for how the app can deleted...... When youre a jackass like me and delete the folder through ssh it's quite simple ha. So that being said if someone has an iPad 2 and can upload the file for me that would be great. It's located in your application folder. Or you can also access it through var/stash/applications. It's the "mobilecal" folder I need. Prior to Ryan pertch loading belfry I was trying to modd myself and accidentally deleted mobilecal instead of mobilecalc.
    Anyway thx for the one that does it for me it's easy and it will not give me any of your info it's simply a file for your iOS system not where your personal info is stored!!
    97693
    858 times
    Sep 2011
    Michigan. USA
    18,178
    Aha-I should have known, have you tried to search our hack section for answers?
    iPad Hacking
    65353
    Jun 2011
    Los Angeles
    11
    No good call thx!!!
    13576
    1454 times
    Aug 2010
    Western NY state (USA)
    11,066
    Sorry, can't help (I don't have an iPad2 ... wouldn't want to risk different files versus the iPad1).
    But, I am going to move this post to the Hacking section. Please, don't post about the same problem in more than one thread. It fragments the conversation and makes it difficult to follow. It's also against forum rules.
    So, I've deleted your other post. Please make any further comments or additions to this thread only (for this problem). Thanks for your understanding.
    skimonkey likes this.
mobilecal ipad
my ipad 2 was erased because someone tried hacking in
