Results 1 to 10 of 16
    4655
    May 2010
    Australia
    7
    Battery draining 1%/hr after Spirit Jailbreak
    Hello, im Ben from Australia, nice to meet you all.
    I've purchased a 64gb3g about a month ago and after jailbreaking the iPad with Spirit, I noticed a degrade in battery performance. If I were to charge the iPad to 100% and pull the plug out before I sleep, the iPad battery would drop to 93% the next morning.
    I initially thought it was something I installed via cydia that was constantly running in the background eating up my battery like sbsettings/winterboard etc.
    So I did a full DFU restore without restoring any backups, a whole clean slate and tested again. After a full charge before bedtime, the iPad was still sitting at 99% the next morning 'even with Fetch for Mail set up hourly'.
    The following night, all I did was jailbreak with Spirit and installed Cydia, no apps or anything else was installed. Again, the battery dropped to 94% overnight. The iPad was restored with os3.2 with no backups restored and only jailbroken with Cydia installed, nothing else. Bluetooth/Location services were all off. Email fetch for Mail was set up hourly.
    The battery on my iPad will continually drop throughout the day at a rate of approx 1%/hr after jailbreaking the device. (When not in use, sleep mode).
    Are any of you experiencing the same problem, is this the norm for a jailbroken iPad? Any advise would be great, thanks in advance!
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    You can expect slight battery decrease with jailbreaking.
    1% per hour seems about right, adds up to 100 hours.
    By around 4:00PM my iPad is down to about 32% left. Thats 10 hours after removing from the power plug in the morning and the iPad is rated to have about 9 hour battery life, 8 and a half if its a 3G model.
    iPad Guru
    1284
    6 times
    Mar 2010
    2,623
    if its 3G its just the radio thats draining it....if I don't use mine for a day it doesn't change...but its wifi only.
    4655
    May 2010
    Australia
    7
    The 3G radio itself does not drain the battery of 1%/HOUR (Sleep mode). When I restored the iPad and didn't jailbreak it, the battery was normal.
    Anyone else who has jailbroken their iPad with Spirit noticed a dramatic decrease in battery life?
    iPad Ninja
    5175
    2 times
    May 2010
    2,032
    I disabled SSH, which I read was a problem with jailbreaking/battery life, and since, have not had any issues.
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    Quote Originally Posted by Matth3w View Post
    Yes SSH drains the battery rather quickly but he said he didnt install anything after the jailbreak.
    suprablitz Jailbreaking can cause these battery drain issues. Either you accept the shorter battery life or dont jailbreak and restore it back to normal.
    4655
    May 2010
    Australia
    7
    I'm more than happy to accept the shorter battery life in exchange for the benifits of jailbreaking. But I was just wondering if this was normal and all the Spirit jailbreakers were in the same boat, that's all. Thanks guys for your input!
    iPad Ninja
    5175
    2 times
    May 2010
    2,032
    Quote Originally Posted by MikesTooLz View Post
    Yeah but I didn't manually install SSH. It was installed with something else I installed like Rock or Cydia, I think. I certainly didn't purposely download it. I forget how I even disabled it because I didn't install it.
    3851
    18 times
    May 2010
    Miami, FL
    2,366
    SSH doesnt get installed with cydia but some other apps require it.
    You can install an SBSettings ON/Off switch for SSH. SSH automatically is turned on after each reboot. SBSettings makes it simple to turn back off.
    iPad Ninja
    5175
    2 times
    May 2010
    2,032
    It must have been something else then. Either way I deleted it completely...any chance you can refresh my memory of how I did that? Did I just go into Cydia and manage?
  1. iPad Spirit Jailbreak Tutorial Video
    By Sonny Burnett in forum iPad Hacking
    Last Post: 01-22-2011, 11:42 PM
  2. Tips on draining ipad battery?
    By Mv-ixius in forum iPad General Discussions
    Last Post: 01-02-2011, 10:33 PM
  3. New spirit jailbreak
    By Panthor in forum iPad Hacking
    Last Post: 06-29-2010, 12:27 PM
  4. iPad Spirit Jailbreak Released
    Last Post: 05-03-2010, 02:57 PM
cydia eat my battery
does jailbreak drain battery
does jailbreaking decrease battery life
does jailbreaking drain battery
does jailbreaking kill battery
does ssh drain battery
ipad 2 battery life after jailbreak
ipad jailbreak battery
jailbreak battery life
jailbreak drain battery life
jailbreak ipad battery life
ssh battery life ipad
