Need help with Iconoclasm
This is a discussion on Need help with Iconoclasm within the iPad Hacking forums, part of the Apple iPad Discussions category; I purchased and installed Iconoclasm and tried it out. Now no matter what I do I can only get three rows of icons. What am ...
Page 1 of 3 1 2 3 LastLast
Results 1 to 10 of 22
    44421
    4 times
    New England, USA
    71
    I purchased and installed Iconoclasm and tried it out. Now no matter what I do I can only get three rows of icons. What am I doing wrong???
  2. #2
    44421
    4 times
    New England, USA
    71
    Quote Originally Posted by rickyricardo View Post
    Please.....................anyone???
  3. #3
    44421
    4 times
    New England, USA
    71
    Well I figured out how to remove the app (new to cydia) but when I re started my ipad I am stuck with 5x2 icons. Really need some help here people....................thanks.
  4. #4
    13576
    218 times
    Aug 2010
    Western NY state (USA)
    5,112
    Iconoclasm is a base for icon placement on a jail broken iPad. It comes with only a few icon layouts. Those layouts are accessible in the Settings app, under Iconoclasm > Uniform Layout. The selection that comes by default is limited. If you want more, press the button "Get More Layouts" (in that page), which will take you to Cydia. Then, you can browse to your heart's content.
    Or, you can go directly to Cydia, select the "Sections" tab, scroll down to the line titled "Addons (Iconoclasm)" and browse that way (it's the same - the one from the app is just a direct link).
    Ulitmately, finding a good Iconoclasm set-up is pretty much trial and error. You'll just have to keep applying ones you think sound good, respring and see if they work for you.
    Me, personally: I have Iconoclasm installed and I'm using the default setting of Five-Column SB (5x4), which can be found under the Uniform Layout box in Settings. This layout gives me a five column with four row layout - in both portrait and landscape. Which is what I like because it stays consistent. YMMV.
    Hope some of this helps.
    P.S. Oh, and please give the forum a bit more of a chance to respond than 10 hours. This is an international forum and sometimes, people haven't even read your post before you "bump" it. All you do, with constant bumping, is annoy the other forum members - and break our rules! Thanks for your understanding ... and patience.
    Black 64GB WiFi/4G iPad3 (iOS 5.1.1; jailbroken w/Absinthe 2.0) & black 64GB iPhone 4S (iOS 5.0.1; jailbroken w/Absinthe 1.0)
  5. #5
    44421
    4 times
    New England, USA
    71
    Thank you Marilyn for your response. I appologize for being impatient but I was thinking that maybe I was going to have to restore my ipad and then rejailbrake it. If that is the case I obviously would want to do it before Apple stops signing 5.0.1. But I will try and be more patient in the future.
    Thanks for your explaination of how iconoclasm works but that is exactly how i have been using it. I go to settings, find iconoclasm and make a selection and then I respring. Problem is, no matter what choice I make I only get two rows. If I chose the one that you suggested I will only get two rows of four instead of 5 rows of four. Are you using Ipad 2 recently jailbroken on IOS 5 ?
    It just isnt working for me, even after removing it my home page is stuck with only 2 rows of icons.
    thanks for your time................rick
  6. #6
    14571
    244 times
    Sep 2010
    Troon, Scotland
    5,410
    You realise you need to move your icons onto the page don't you? If you set a 5x5 grid you need to move 25 icons on there to fill it. The iPad doesn't reflow icons to fill previous pages automatically. It only pushes them forward when a page is full.
    13" MacBook Pro 8GB 2.7GHz i7 500GB | iPad3 4G 64GB 5.1.1 (stock) | iPad2 3G 64GB 5.0.1 (absinthe) | iPad1 3G 64GB 5.1.1 (redsn0w) |
    iPhone4S 64GB 5.0.1 (absinthe) | iPhone4 32GB 4.3.3 (jbme 3.0) | iPhone3G 16GB 3.1.3 (jbme 2.0) |
    iPod Classic 6G 160GB (stock) | AppleTV 2G 4.4.4 (seas0npass)
    If it ain't broke... Jailbreak it!
  7. #7
    13576
    218 times
    Aug 2010
    5,112
    To add to what f4780y said: If you use Gridlock (which I do), you won't have to fill up the page. Gridlock will allow you to put an icon anywhere Iconoclasm would have if you were filling the page.
    IOW - no Gridlock means you must fill the page, as f4780y says.
    Sorry I wasn't more clear before...
  8. #8
    44421
    4 times
    New England, USA
    71
    Quote Originally Posted by Mickey330 View Post
    Okay, now I feel like an idiot! No I did not realize I have to move icons over myself. Let me try and figure out how to do that and I will get back to you.
    Thanks so much for your information..................rick
    Okay, I figured it out. Thank you both very much for your help. I obviously have a lot to learn about my ipad.
  9. #9
    Fid
    Fid is offline
    116331
    Oct 2011
    Hinterlands of Northern California
    124
    @RickyRicardo - Thank you for starting this thread.
    I just downloaded iconoclasm and didn't know where to find it since I didn't get an icon. I looked in the Settings and found it, but I had no idea about using it. I was under the impression that I would be able to move the icons to wherever I wanted, like unchecking the auto-arrange on a MSWindows desktop.
    Right now I am using a 5x5 because I had all of my icons in related pages. That is to go by the wayside shortly.
    Sent from my iPad using iPF - Peace
    That upon which you dwell in the mind you become. - Lao Tsu
    iPad1 32GB, iPhone 4 - 32GB, iPod Shuffle
    1GB
  10. #10
    14571
    244 times
    Sep 2010
    Troon, Scotland
    5,410
    Quote Originally Posted by Fid View Post
    Iconoclasm arranges icons into pre-defined patterns or layouts, e.g. 5x5, 6x8, or "L shaped".
    Gridlock is the tweak that lets you move icons wherever you like without them auto-arranging (filling in any blanks you create).
    You can combine both tweaks to allow you to set a non-standard pattern or layout and then arrange the icons at will within those patterns.
Sponsors
change settings to iconoclasm layout
five rows for ios 5.1
how to install iconoclasm
how to make iconoclasm
how to put icons wherever you want in iconoclasm
how to set iconoclasm
iconoclasm and errors trying to install addons from cydia
iconoclasm for ipad 2
iconoclasm icons anyware
iconoclasm ipad 2
iconoclasm layouts not showing up in settings
iconoclasm layouts not working for ios 5.1
iconoclasm layouts wont download
iconoclasm mess up folders ios5
iconoclasm not working 5.1
iconoclasm uniform layout extras layout
stop ipad icons from auto arranging
use gridlock with iconoclasm
what is extras layout for iconoclasm
where do i purchase iconoclasm for ipad?
