Battery life after jailbreak
This is a discussion on Battery life after jailbreak within the iPad Hacking forums, part of the Apple iPad Discussions category; Is anyone noticing a significant loss of battery life since the jailbreak? I think my ipad2 may be a little heavier on battery but I ...
Is anyone noticing a significant loss of battery life since the jailbreak? I think my ipad2 may be a little heavier on battery but I am putting it down to tweaks like intelliscreenX because of its data usage. My iPhone 4s however has only been jailbroken with out tweaks or cydia apps and it seems to be really chewing through my battery.
01-22-2012 01:10 PM
The jailbreak itself has not effect on battery.
However, the more tweaks you put on there the more battery you will use. It's simple logic. Tweaks run in the background doing their thing, chewing up CPU cycles and draining your battery. If you install old or badly coded tweaks, or particularly complex themes with widgets, you should expect to see worse battery life than before you had any of that additional stuff installed.
13" MacBook Pro 8GB 2.7GHz i7 500GB | iPad3 4G 64GB 5.1.1 (stock) | iPad2 3G 64GB 5.0.1 (absinthe) | iPad1 3G 64GB 5.1.1 (redsn0w) |
iPhone4S 64GB 5.0.1 (absinthe) | iPhone4 32GB 4.3.3 (jbme 3.0) | iPhone3G 16GB 3.1.3 (jbme 2.0) |
iPod Classic 6G 160GB (stock) | AppleTV 2G 4.4.4 (seas0npass)
If it ain't broke... Jailbreak it!
And it could also be the extra amount of time you spend tweaking your iPad after a jailbreak. We all do it, guilty as charged yer 'onour
The world is a dangerous place to live, not because of the people who are evil, but because of the people who don't do anything about it!!
64gb wifi ipad2 iOS 5.01 (Jailbroken using Absinthe) : 120GB iPod Classic : AppleTV2 iOS 4.4.4 (Jailbroken using seas0npass)
My battery life was terrible after the jailbreak and all I installed was SBSettings. With my phone idle (screen off), it would drain about 10% an hour.
I did a restore to remove the jailbreak and I'm now back to draining about 1%-2% an hr.
EDIT: Forgot to add that this is on an iPhone 4S
Reason: Forgot additional info
I'll turn off WiFi only on my iPhone 4 tonight, leave it off the charger, and report back tomorrow morning what it does. I don't have a lot of themes or tweeks, but do have SBS, MyWi, and a few other things. I've only had 5.0.1 and the JBs on the pad and phone for a couple of days and haven't taken the time (or even thought about) trying to measure the comparitive batter drain. Thanks for the suggestion.
Brian - Sent from my iPad using iPF
Brian
(sent from my iPad)
Originally Posted by
Bingoldsby
As offered above, I left both the iPad and the iPhone - fully charged - off the charger for the night (8 full hours). When I got up this morning the phone was still at 100% and the iPad was at 98%.
The phone had location services ON, but only for two services which had not requested a location in that period. The iPad also has location services ON, and both had location requests in the 24 hour period (Free WiFi finder and Maps).
So, I have to say that the quiescent battery draw on both my devices is VERY LOW.
Brian
(sent from my iPad)
- You may not post replies
- You may not edit your posts
Forum Rules
By F4riz in forum iPad 2 Forum
Last Post: 01-08-2012, 10:26 AM
By hinke00 in forum iPad 2 Forum
Last Post: 10-28-2011, 09:56 PM
By User77 in forum Off-Topic
Last Post: 03-02-2011, 01:22 AM
By emilyjane918 in forum iPad General Discussions
Last Post: 05-04-2010, 10:14 AM
By msskarina in forum iPad General Discussions
Last Post: 05-02-2010, 08:12 AM
absinthe battery drain
absinthe battery life
absinthe jailbreak battery drain
after jailbreak battery life iphone 4
after jailbreak battery problem
battery issues after jailbreak
cydia applications drain ipad battery
does jailbreak kill battery life
does jailbreaking drain battery
does jailbreaking kill battery life
ipad 2 battery drain after jailbreak
ipad 2 battery life after jailbreak
ipad 2 jailbreak battery drain
ipad battery life after jailbreak
ipad jailbreak battery life
iphone battery life after jailbreak
jailbrake battery life
jailbreak and battery life
