i go on winterboard choose the theme/slider and then i respring and nothing happens
so if any 1 could help me that great thanks![]()
This is a discussion on Help Changing the slide to unclock icon within the iPad Hacking forums, part of the Apple iPad Discussions category; i go on winterboard choose the theme/slider and then i respring and nothing happens so if any 1 could help me that great thanks...
If you are new to iPad themeing or jailbreaking then the biggest surprise you will get is that >95% of the themes you see in Cydia are for the iPhone and will NOT work on the iPad. Winterboard works by substituting graphics (and other) files over the original operating system ones. On the iPad the names and dimensions of the graphics are often considerably different than the iPhone. Hence the reason, most themes don't work.
Have a look at our themes section within this forum for some ideas, but as a general rule of thumb, if the theme in Cydia does not have "iPad" in the title, it won't work very well on our devices...
Hope that helps.
13" MacBook Pro 8GB 2.7GHz i7 500GB | iPad3 4G 64GB 5.1.1 (stock) | iPad2 3G 64GB 5.0.1 (absinthe) | iPad1 3G 64GB 5.1.1 (redsn0w) |
iPhone4S 64GB 5.0.1 (absinthe) | iPhone4 32GB 4.3.3 (jbme 3.0) | iPhone3G 16GB 3.1.3 (jbme 2.0) |
iPod Classic 6G 160GB (stock) | AppleTV 2G 4.4.4 (seas0npass)
If it ain't broke... Jailbreak it!
