Miwifi 5.0 breaks the Ipad's exisitng Wifi connection
This is a discussion on Miwifi 5.0 breaks the Ipad's exisitng Wifi connection within the iPad Hacking forums, part of the Apple iPad Discussions category; Miwifi 5.0 works fine with AT&T 3G. When My Ipad is using 3G, I turn the wifi hotspot on, My Ipad can browse the internet ...
Miwifi 5.0 works fine with AT&T 3G. When My Ipad is using 3G, I turn the wifi hotspot on, My Ipad can browse the internet and another Ipad sees the network, can connect and browse the internet as well.
The problem is with Wifi. I connect my Ipad to my wpa2 router and verify internet connectivity. I then Launch Miwifi 5.0 and turn the hotspot on. The app reports that I have no network connectivity and suggests cycling the airplane mode settings. This does not help. After these steps, my Ipad has no wifi connectivity. The settings show it is connected to the new hotspot which has can not go anywhere on Safari. I can switch to the my original wifi and see that it picked up an ip from my router, however, I am unable to go anywhere on Safari. I can browse with 3g. I am only able to get out with wifi after I restart the device. I tried this several times.
Also, now My ipad no longer auto connects to my home wifi, requiting me to tap it.
Are these known issues?
Please advise.
01-21-2012 06:37 PM
You can't use your iPad to both connect to a WiFi network and offer up a WiFi hotspot. You can do one or the other. Not both.
13" MacBook Pro 8GB 2.7GHz i7 500GB | iPad3 4G 64GB 5.1.1 (stock) | iPad2 3G 64GB 5.0.1 (absinthe) | iPad1 3G 64GB 5.1.1 (redsn0w) |
iPhone4S 64GB 5.0.1 (absinthe) | iPhone4 32GB 4.3.3 (jbme 3.0) | iPhone3G 16GB 3.1.3 (jbme 2.0) |
iPod Classic 6G 160GB (stock) | AppleTV 2G 4.4.4 (seas0npass)
If it ain't broke... Jailbreak it!
Thanks 4 the quick reply.
The lack of the feature does not cause any harm, as If I wanted any devices on a wifi network that I control to connect to it, I could simply connect them.
I still no longer auto-connect to my home wifi. This happened after I used miwifi. I have restarted since. Not a huge inconvenience, but is this a known bug, and how can I get the Ipad to auto-connect to my own network.
- You may not post replies
- You may not edit your posts
Forum Rules
By mamurao in forum iPad 2 Forum
Last Post: 01-03-2012, 07:08 PM
By linnormlord in forum iPad Help
Last Post: 07-05-2011, 08:13 PM
By ad0586 in forum iPad Help
Last Post: 06-04-2011, 08:16 AM
By King in forum iPad 2 Forum
Last Post: 04-19-2011, 06:17 AM
By nparab in forum iPad Hacking
download miwifi5.0
hotspot-5.0.1
how to enable wifi hotspot on ipad 2 5.0.1
how to get hotspot for ipad 2 3g 5.0.1
how to make ipad 2 a wifi hotspot using 3g
how to turn on 3g hotspot 5.0.1
how to use miwifi
ipad 1 wifi hotspot
ipad 2 breaks wifi connection
ipad 2 wifi autoconnect
ipad hotspot 5.0.1
ipad turn hotspot 5.0.1
miwifi
miwifi 5.0
miwifi5.0 not connecting
miwifi5.0.ipa
turn ipad 2 into hotspot
turn ipad into wifi hotspot 5.0.1
turn your ipad2 5.0.1 into a hot spot
wifi hotspots for ipad2 5.0.1
