Problem with redsnow b4
This is a discussion on Problem with redsnow b4 within the iPad Hacking forums, part of the Apple iPad Discussions category; OK, I have an ipad 1 WiFi only model it has been jailbroken on 4.3.3 then I about two weeks ago I upgraded to the ...
Results 1 to 10 of 12
    53704
    May 2011
    7
    Question Problem with redsnow b4
    OK, I have an ipad 1 WiFi only model it has been jailbroken on 4.3.3 then I about two weeks ago I upgraded to the 5.0.1 jb using redsnow b1. I updated the unit to the b3 files when they came out and had to do the manual ibooks fix to get that to work. so yesterday I seen that redsnow is now running b4 and that should fix all my problems, so this morning I decided to update to b4.
    Well, I tried to put the unit into dfu mode and when it found the unit to go to jb, it says error with shsh blobs........WTF
    so after I got the unit to power on correctly, I went into cydia and looked at what blobs are there, and low and behold it shows all from 4.2 all the way up to 5.0.1
    So what to do now? I have the ipad plugged into the PC, still in hopes that someone can point me in the correct direction to get this working. I have NEVER had any problems with ANY device i have JB in the past or currently. I have followed all directions, and nothing seems to work. I even tried to send the blobs to cydia, tried to get the blobs on the unit to go through, and NOTHING works.
    Any and all help is appreciated.
    Da Duck
  2. #2
    Banned
    12904
    32 times
    Aug 2010
    Raleigh, NC USA
    3,664
    If you use TinyUmbrella to save your blobs, open it up, and click on the advanced tab. Make sure the box for "set hosts file to Cydia on exit" is unchecked.
    Then, plug your iPad into iTunes, sync, and then use DFU mode and let iTunes do a normal restore. No custom firmwares or anything. Just a clean, normal restore. Then you can re-jailbreak with beta 4.
  3. #3
    53704
    May 2011
    7
    Thank you for your help.
    So I downloaded the newest TU, ran it like the tut said made the check markes like it said to, then downloaded the IshsIT and sent the blobs to my email.
    I then restored the ipad (which erased my tweaks and all) and after the restore, I tried to do the JB again, and BOOM the same thing.
    I have the current blobs, and cydia shows them also. so now I am at a loss.
    Any other ideas?
    Thank you
    Da Duck
  4. #4
    14571
    244 times
    Sep 2010
    Troon, Scotland
    5,410
    The jailbreak process with redsn0w does not make any use of blobs whatsoever. They are completely irrelevant. It does not sound like you are choosing the right option at all.
    Please post the EXACT error message which is shown when you press the "jailbreak" button in redsn0w.
    13" MacBook Pro 8GB 2.7GHz i7 500GB | iPad3 4G 64GB 5.1.1 (stock) | iPad2 3G 64GB 5.0.1 (absinthe) | iPad1 3G 64GB 5.1.1 (redsn0w) |
    iPhone4S 64GB 5.0.1 (absinthe) | iPhone4 32GB 4.3.3 (jbme 3.0) | iPhone3G 16GB 3.1.3 (jbme 2.0) |
    iPod Classic 6G 160GB (stock) | AppleTV 2G 4.4.4 (seas0npass)
    If it ain't broke... Jailbreak it!
  5. #5
    53704
    May 2011
    7
    I also tried to stitch the blobs and this did not do the trick either.........
  6. #6
    53704
    May 2011
    7
    The error is this
    that's all it says. this does come up after trying to JB ( after holding the power for 3 sec., and then holding the home button with the power, then releasing the power and holding the home button, and when it makes the sound that the unit is connected, it goes back a screen through redsnow and shows the error on the bottom left hand side of that screen
  7. #7
    14571
    244 times
    Sep 2010
    Troon, Scotland
    5,410
    On the Extras menu, use "Select IPSW" and point redsn0w to a copy of 5.0.1 firmware for your device (which you will have to download if you don't already have it).
    Then use the "jailbreak" button.
  8. #8
    53704
    May 2011
    7
    Couldn't download required IPSW
    Please check your internet connection
    if your internet is working you may need an updated version of redsnow
    error with shsh blobs!
    This is all that the screen shows when it goes to the error, sorry I did not think of putting that down before.
  9. #9
    53704
    May 2011
    7
    YOU ARE THE MAN, I just got the jb moving with the select IPSW.
    THANK YOU THANK YOU THANK YOU.
    I was going nuts for the past couple hours trying to figure out what I did....LOL
    Speaking of which, do you know why or what might have caused this error?
  10. #10
    14571
    244 times
    Sep 2010
    Troon, Scotland
    5,410
    The error message told you, it couldn't download the IPSW file itself (for whatever reason).
Sponsors
  1. Questions about redsnow and snowbreeze
    By osutrooper in forum iPad Hacking
    Last Post: 11-15-2011, 02:31 PM
  2. redsnow + 4.2.1 jailbreak questions thanks
    By rian123 in forum iPad Hacking
    Last Post: 06-14-2011, 04:51 AM
  3. After jail broken with redsnow......
    By Xpreso in forum iPad Help
    Last Post: 02-17-2011, 10:44 PM
  4. redsnow jailbreak... reboot only SOL....?
    By Rokr in forum iPad Hacking
    Last Post: 02-03-2011, 06:38 AM
  5. how to get redsnow to run in xp mode?
    By Dr.Gee in forum iPad Hacking
    Last Post: 12-08-2010, 09:12 PM
coudnt downlaod required ipsw
couldn't download required ipsw
couldn't download required ipsw error with shsh blobs
couldn't download required ipsw redsn0w
couldn?t download required ipsw! please check your internet connection. if your internet is working, you may need an u
error shsh blobs redsn0w
error with shsh blobs 5.1
error with shsh blobs redsn0w
error with shsh blobs redsnow
problems with redsnow
redsn0w couldn't download required ipsw
redsn0w couldnt download required ipsw error with shsh blobs
redsn0w error with shsh blobs
redsn0w shsh blob error
redsnow couldn't download required ipsw
redsnow couldn't load required ipsw
redsnow error with shsh blobs
redsnow shsh blobs error
redsnow sound problems
