my JB ipad2 is stuck since i press the reset button, it stuck for 3 hours since i press the reset button, anyone manage to help ?
thanks!
This is a discussion on 求救!ipad 2 reset problem, it stuck ~~~ within the iPad Hacking forums, part of the Apple iPad Discussions category; my JB ipad2 is stuck since i press the reset button, it stuck for 3 hours since i press the reset button, anyone manage to ...
thanks!
Good day, mctdevil,
We would suggest that you make a new thread under iPad Hacking for better advise.
Hi, mctdevil:
I'm one of the moderators for the Hacking section. To save you time and effort, I've gone ahead and moved your post to the Hacking section so you don't have to re-post.
Now, from your intro thread, I know you have a JB'd iPad on iOS 4.3.3. To start, may I suggest you try to either restart or reset your iPad? To do:
Reset: Hold both the power and home buttons until the screen goes dark and the Apple logo then appears (the slide to unlock screen may or may not appear). Once the logo appears, release the buttons. After a time, your homescreen will appear. Please note that it may take some time for the Apple logo to appear or for your homescreen to appear (or both). This is normal. Eventually, the homescreen will appear.
If you try either of these (or both!) and they don't help (or, if this is what you did to get "stuck"), please let us know and we'll try something else. Good luck.
Black 64GB WiFi/4G iPad3 (iOS 5.1.1; jailbroken w/Absinthe 2.0) & black 64GB iPhone 4S (iOS 5.0.1; jailbroken w/Absinthe 1.0)
