Unkown error problem
This is a discussion on Unkown error problem within the iPad Hacking forums, part of the Apple iPad Discussions category; Hi everyone, After trawling the net for two days and finding no answer to my jail breaking problem I have resorted to asking for help, ...
Results 1 to 3 of 3
    143436
    Dec 2011
    London
    Hi everyone,
    After trawling the net for two days and finding no answer to my jail breaking problem I have resorted to asking for help, I hope a reader of this forum may have some ideas! I have a jailbroken ipad 1 running a tethered version of 4.3.1. I'm eager to install the untethered version of 5.0.1 which I recently downloaded but every time I try to shift+restore I get the message 'This ipad cannot be restored because of an unknown error [21]'. When I check the apple support pages it suggests it might be a security problem but other than windows firewall (which I've disabled) I don't have any security programs? When googling the problem a lot of pages suggest using iREB. I downloaded this and put it into the necessary state and then retry but get the same message with error 1603?? Does anyone have any ideas, it's so frustrating?
    Banned
    12904
    34 times
    Aug 2010
    Raleigh, NC USA
    3,655
    Have you ever used a program called TinyUmbrella? If so, it sounds like your hosts file is screwed up.
    backup your iPad first.
    If you use TinyUmbrella, open it up and go to the "advanced" tab. Then uncheck the box "set hosts to Cydia on exit". Close TU.
    Now, plug your iPad into iTunes and use DFU. Press and hold the power and home button for 10 seconds, then, release the power button but keep holding the home button until iTunes recognizes a device in recovery mode. Then just hit "restore". No shift select junk.
    Then once the iPad is restored, just run the latest redsnow to jailbreak.
    143436
    Dec 2011
    London
    Thanks for your response graywolf )) I have tiny umbrella so I'll give it a shot now and let you know what happens. Thanks again for the help!
  1. dfu error
    By Max7150 in forum iPad Hacking
    Last Post: 02-22-2012, 01:33 PM
  2. PDF error
    By alanjdoolan in forum iPad Help
    Last Post: 12-04-2011, 04:31 PM
  3. Unkown error after accepting new licence terms...
    By DrHouse in forum iPad General Discussions
    Last Post: 10-12-2011, 06:08 AM
  4. Garageband problem or ipad2 touchscreen problem?
    By Summy73 in forum iPad Apps
    Last Post: 06-02-2011, 05:35 PM
  5. Error 28
    By Flakin' Jamaican in forum iPad Help
    Last Post: 12-15-2010, 08:36 PM
error 1603
error 21
ipad 2 cannot restore unknown error 21
ipad cannot be restored error 21
ipad cannot be restored unknown error (28)
ipad restore error 21
ipad restore issues unknown error
ipad restore unkown error 21
ipad unknown error 21
this ipad cannot be restored 1603
unable to restore ipad unknown error 21
unknown error 21 ipad
